Results 1 to 3 of 3
    Installing internal routed brake
    What is the procedure for installing pre-bled brakes on an internally routed frame? Do I need to bleed all the fluid before installation, or can I just cut hose and thread it, not worrying about any fluid coming out? I understand that I will perform a bled after installation. Thx Pete
    Reputation: Shalom's Avatar
    Nov 2008
    Guess it depends on the brake. If DOT, then I would completely drain the line. Mineral oil I might drain, depending on frame material.
    New, dry line through the frame. You will have to cut off a section of hose that includes the barb, so if you aren't sure you have extra length, that could create binding.
    At the very least, drain the line and put a turn on plastic wrap over the cut end, as you don't want any hydraulic fluids hanging out inside your frame.
  1. Replies: 0
    Last Post: 10-10-2012, 04:35 PM
  2. Replies: 1
    Last Post: 08-07-2012, 01:06 PM
  3. Replies: 1
    Last Post: 08-07-2012, 07:59 AM
  4. Internally routed brake housing - pros and cons
    By rasse1977 in forum Brake Time
    Last Post: 01-17-2012, 01:07 PM
  5. Replies: 10
    Last Post: 06-02-2011, 04:36 AM
