Results 1 to 6 of 6
    installing hayes mag plus
    i am about to install a set of hayes mag+ disc brakes. the manual says i need to use a torque wrench. is this abbsolutely necessary or can i get by w/o using it and just tighten it with a wrench? torque wrenches are $50-$70 and i dont know if i would use it much after installing the brakes. advice?
    thanks
    You can get the Park for $35, or the same thing with a foot...
    Quote Originally Posted by crapsneleven
    thanks
    ...pound scale which you can convert to inch pound by multiplying by 12 for $20 through Sears.
    http://www.worldcycling.com/merchant...&Category_Code=
    Craftsman Beam Torque Wrench, 3/8 in. Drive
    Beam-type. Separate English and Metric scales. Graduated indicator tip offers line-on-line reading to help eliminate parallax error. Torque accurate to 4 percent.
    <TABLE cellSpacing=0 cellPadding=0 border=0><TBODY><TR><TD></TD><!-- End left margin --><!-- Start main left nav/callout column --><SCRIPT language=JavaScript> function goMoresOfSears(url) { var moresWin= window.open(url, 'popup', 'height=500,width=500,resizeable,scrollable,scroll bars=yes'); moresWin.focus(); }</SCRIPT><!-- Start main left nav/callout column --><TD vAlign=top><!-- Start logo/save story table --><TABLE cellSpacing=0 cellPadding=0 width=135 border=0><!-- Start formatter row --><TBODY><TR><TD></TD><TD></TD><TD></TD><TD></TD></TR><!-- End formatter row --><!-- Start logo row --><TR><TD align=middle colSpan=4></TD></TR><!-- End logo row --><TR><TD colSpan=4></TD></TR><!-- Start save story row --><TR><TD vAlign=bottom bgColor=#cccccc></TD><TD></TD><TD class=c000bfffs075r vAlign=top>$19.99
    Rebate details
    Note: these tools look to be identical, except for the calibrations being different, the English calibrations (Newton meters) should be the same. Most reputable component manufacturers list Newton meters in their torque specifications.
    </TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE>
    rr
    rr is offline
    I don't do PC
    Reputation: rr's Avatar
    thanks
    You can crank on the caliper bolts, but they don't need to be super tight. The small allen screws for the levers are delicate and should not be tightened too much, the heads will wallow out if you over tighten.
    Quote Originally Posted by rroeder
    this can easly be solved by getting some 4mmx0.7 at 20 or 25 mill meters long.
    you can get a bag of two for like 38 cents. they will be flat head not allen though. works for me
    Reputation: E-man's Avatar
    Quote Originally Posted by snipes287
    this can easly be solved by getting some 4mmx0.7 at 20 or 25 mill meters long. you can get a bag of two for like 38 cents. they will be flat head not allen though. works for me
    And replace the chi-chi Ti bolts that came in with the Mag Plus? Are you kidding? The Ti hardware (and the carbon levers) are one of the main reasons these brakes cost so much.
    I'm running the Mag Plus brakes on my Intense 5.5. There's no need to worry about using a torque wrench. Just use common sense and you'll be fine.
    Eric
    Oakley - High Definition Optics
    didn't know there was a diff between the mag plus and the mags
  1. Romic or Swinger 4way coil for 5 Spot
    By Alpenglow in forum Turner
    Last Post: 05-19-2004, 06:20 PM
  2. Hayes Mag lever reach adjustement loose?
    By ptolar in forum Brake Time
    Last Post: 03-12-2004, 07:58 AM
  3. Hayes or Avid for the Fuel?
    By Spaz in forum Trek
    Last Post: 02-23-2004, 05:13 PM
  4. Hayes or Avid for an '01 Fuel 90? (x-post)
    By Spaz in forum Brake Time
    Last Post: 02-10-2004, 08:01 PM
  5. Replies: 8
    Last Post: 01-20-2004, 03:20 PM
