    Inconsistent Lever Feel XT disc brake
    I have the current generation XT disc brakes. I bought them as a pre bled set up.
    The front brake feels fine.
    The rear brake has an inconsistent feel to it. When I first use the brake it is fine. But with repeated lever pulls on sustained downhill the lever pull is short and engages early in the lever pull.
    Any ideas?
    Quote Originally Posted by mastakilla View Post
    Any ideas?
    I have a set of M785 with Goodridge braided lines and ice tech rotors and finned pads that do the same thing. The front brake seems to stiffen up just a tiny bit on long downhills - it's barely noticeable. The rear brake seems to do it a little bit more. I recently re-bled the rear brake and got the exact same lever travel and feel as before.
    I'm wondering if it's just fluid expansion from the heat. The rear line is about 2x as long and therefore has 2x the fluid and would expand more.
    I don't think it's anything to worry about. As long as your pads don't drag the brakes return to their normal feel quickly after the downhill is over.
    El CicloPath!!!!!!!
    Nov 2012
    There may be too much fluid in the system. Crack the bleed screw at the lever open a bit and see if any fluid flows out.
    Mine do this when the pads are about half gone. Two sets, same quirk, quite a few pads at this point. Try a new set of pads, or a bleed, or both. Annoying feature with the XT's.
  1. Replies: 4
    Last Post: 06-11-2013, 01:11 PM
  2. Replies: 2
    Last Post: 01-09-2013, 03:39 PM
  3. $100 shipped XT 785 front disc brake lever/hose/caliper
    By westin in forum Where are the Best Deals?
    Last Post: 07-20-2012, 05:40 PM
  4. Hardrock Disc Brake Lever Adjustment
    By dharel1705 in forum Specialized
    Last Post: 05-23-2012, 05:23 PM
  5. Shimano xt brake inconsistent engagent
    By Brendan J in forum General Discussion
    Last Post: 06-24-2011, 11:47 AM
