Results 1 to 5 of 5
    Inconsistent braking, whats the reason?
    My front brake is giving inconsistent braking forces. Its almost like 1/3 of the rotor is clean and the pads grab it strongly while the rest has some contaminant. Its also something like braking with rim brakes with a buckled rimÖ
    Iíd have thought if it was contaminant then it would have spread round the whole rotor. Is it something like the thickness of the disc? Or the way it has been manufactured? I think Iíve had this problem with an old hope rotor (maybe shimano actually?)
    Hope M4ís, new (fairly bedded in) superstar Kevlar pads, superstar 200mm vibe rotor. No problems with those parts previously.
    Interestingly I used the same superstar rotors for a week in morzine and they suffered a huge amount of wear. So much so Iíve bought new ones. There a chance that they not been hardened properly? Or do the discs need gently bedding in as well as the pads? Hurling the bike down les gets might not have done them good in the long term?
    source of the rotor for those confused by the brand: superstar.tibolts.co.uk/product_info.php?cPath=50&products_id=200
    Reputation: Shalom's Avatar
    Nov 2008
    Try cleaning the rotors with brake cleaner. See if that helps.
    Otherwise - does it take a while to grab initially? Or is that third/two thirds grip happen all the time?
    I'll have to go search for some brake cleaner - any recommended products?
    the third/two thirds grip thing is all the time. more noticeable with cold brakes.
    Nov 2008
    Being in New Zealand, I am not sure that what I can get is available to you. Try your LBS. If they do not have some, they should be able to point you in the right direction.
    Can you feel that braking force is oscillating with a frequency proportional to your speed even if the rotors are clean?
    I had such a problem with brand new Avid rotors. LBS mechanic and I came to the conclusion that the rotor thickness was changing at certain regions and causing the problem. New rotor under warranty and everything has been fine ever since.
  1. Code R's too much braking rear braking power?
    By mefistofeles in forum Brake Time
    Last Post: 12-07-2010, 08:10 AM
  2. Inconsistent chain tension?
    By JHANguyen in forum Singlespeed
    Last Post: 12-24-2009, 01:03 PM
  3. Whats a good reason to run tubeless
    By bigguysmallbike in forum Wheels and Tires
    Last Post: 08-01-2009, 08:40 AM
  4. Whats a good Full Suspension with out braking the bank?
    By Sinner in forum Bike and Frame discussion
    Last Post: 03-29-2007, 03:56 PM
  5. Whats the reason for this pivot??
    By SpecialBrew in forum General Discussion
    Last Post: 06-06-2005, 08:04 AM
