Results 1 to 10 of 10
    If only front disc for XC racing, which one?
    XC racing
    SW-Virginia
    hardtail
    135lbs
    Front disc only.
    Not afraid of wrenching but want something easy to work on.
    What are your suggestions?
    Mar 2005
    Front wheel only. I would use the Avid BB7 mechanical. They are super easy to work on, and offer more stopping power and modulation than rim brakes, but less than hydro brakes.
    -R
    nnn
    nnn is offline
    Reputation: nnn's Avatar
    Feb 2005
    Be aware that the BB7 is one of the heaviest discs out there. As for stopping power they beat some of the Hydros out there easily and leave Vs gasping for air.
    I'd suggest either the Shimano Deore XT or XTR or Hope Disc Brakes Like The Mono Minis. Stay away from Hayes, they aren't as good as they used to be.
    Anything worth doing is worth overdoing...
    -Ricko, mtbr member
    aka Willy Vanilly
    Reputation: will8250's Avatar
    Aug 2003
    I'd also recommend the Avid's. A bit heavy but I think they'll match the feel of a cable rear (I'm assuming v-brake) better. Also, they're very easy to work on/adjust. Good luck
    Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction.
    E. F. Schumacher
    sXe
    Jan 2005
    only one?
    not sure if you've used discs before, but had the same thinking as you, getting only a front one (was too poor to get a full set). after about a week i had decided that i couldn't live with vee's anymore, simply because of how much better the disc felt, especially as it was coming into winter when i got it. anyway, just keep in mind that you might be able to get a better deal on a pair bought at the same time rather than one now and one in the future. (or like me, struggle to find a matching brake - the old shimano xt four pots)
    Quote Originally Posted by ashwinearl
    XC racing
    SW-Virginia
    hardtail
    135lbs
    Front disc only.
    I'm not sure if your looking for light weight or low cost, but if your only buying the front break to save weight, you may want to look at the formula B4 SL, or magura marta sl. Both should have plenty of stopping power for a 135lb rider, and both are light weight.
    Kam
    Kam is offline
    A hopped on pop.
    Reputation: Kam's Avatar
    XC racing
    SW-Virginia
    hardtail
    135lbs
    Front disc only.
    if you want to use the same levers as you have for the rear v-brake, and you want something what feels similar to the rear lever, the avid mechs are great.
    quite honeslty, it'll be hard to find something that sets up really easy and has this much power as the avids. i have my avid mechs set up to some ultimate levers and 185/160mm galfer rotors and i am amazed by the power (before install, i placed the pads in my toaster @400* for about 10 minutes, then slightly sanded them). after install, i rode around in the driveway and was doing one-finger nose-wheelies!!!
    they are cheap and ultra reliable/adjustable. they are abit heavy but 100g or so doesn't win/lose races...it's the rider, not the ride.
    if you're looking for a lightweight hydro...check out the shimano and hope offerings. with the shimano stuff, it's going to be hard to find a front-only system. with the hope stuff, you can get a mono mini or m4 and get a pretty nice, reliable system. the hope lines are also VERY easily trimmable. follow the directions (it isn't hard), be patient, and bleeding will not be necessary (they are pre-bled from factory).
    both hope and shimano systems are easy to bleed, no bleed kits needed. you can just use gravity as your friend. with any disc system you chose to look at, a 160mm rotor will be good enough because you are relatively light.
    cheers!
    definitely go with an Avid BB7 disc. It's annoying to have differently shaped brake levers.
    pay me
    Reputation: Duncan's Avatar
    another vote for avid mechs
    If I put a fork on my Kona (it's currently with a Kona P2 rigid fork) I'm going to use avid BB7s. They're great brakes (had them on my 5 spot in the past), simple to set up even for the mechanically dyslexic and, as others have noted, you can still have the same levers front and rear.
    Duncan
  1. 2004 SJ FSR Exp. Disc - shuddering front brakes
    By Richie in forum Specialized
    Last Post: 01-11-2005, 10:39 AM
  2. 28spk front disc wheel thoughts
    By thebronze in forum Wheels and Tires
    Last Post: 11-15-2004, 10:52 AM
  3. Racing Ralph as a front tire?
    By WOY in forum Wheels and Tires
    Last Post: 09-01-2004, 08:33 AM
  4. front disc
    By sbek in forum Brake Time
    Last Post: 04-09-2004, 04:27 PM
  5. which front disc hub similar to XT nondisc?
    By jh_on_the_cape in forum Wheels and Tires
    Last Post: 02-04-2004, 03:52 PM
