Results 1 to 2 of 2
    I need help with my BB7 spring
    I was removing my BB7 rear brake pads, and this small metal butterfly spring popped out. What direction does this go in, and what is the best method for reinserting it?
    Thanks, Doug
    Jul 2003
    Here you go....
    the link is to a .pdf document that gives instructions for J7 and BB7 pad installation. They use the same pads and same methods for installation except for step 1 which is specific to the which brake you have. In your case you would go with the "Open Wide" part of step 1. The "Push the Pistons Back" is for the Juciy 7. Otherwise all steps are the same. The illustrations at the top right show the orientation of the spring.
    http://www.sram.com/_media/techdocs/...B7%20Juicy.pdf
    Good Dirt
