Results 1 to 3 of 3
    I have a magura gustav #11 adapter but need a post mount adapter, Help
    So I have a set of magura gustav brakes and I have two magura #11 adapters part #0721395 (note that these adatpters are also called the #21 adapters in th 2006 magura catalouge, but they are exactly the same at the #11). These adapters will allow you to go from a standar IS mount in the front to a 210mm rotor, or from a standard IS mount in the rear to a 190mm rotor.
    I would like to trade someone one of these adapters for a adapter that will work for a front post mount to a 190mm or 210mm rotor which would be adapter #9 (part numbers 0721379) or #13 (part numbers 0721645), Thanks
    Ryan
    Reputation: daisycutter's Avatar
    gustav issues
    I will look tonight at home to see if I can assit
    Quote Originally Posted by ryan2100 View Post
    Ryan
    Kindly, do you by any chance still have one of these #11 adapters (part #0721395)?
    I am looking for one of these at the moment.
