    Reputation: client_9's Avatar
    Hydro hose leak - Can you over fill brake fluid?
    My rear brake line is weeping brake fluid. Right in the middle of the line (not at a connection or bend) No visible kinks or imperfections in the woven metal. It's Jagwire HyFlow hoses and Elixir CR brakes.
    Just for visual reference:
    Can you over fill brake fluid thus causing too much pressure?
    thanks.
    Dec 2010
    I don't believe so. Especially on Avid brakes. I have Hope Tech brakes, and they have more of a traditional master cylinder. I fill it to the rim, and put the cap on.
    Sounds like a bad hose. I would contact Jagwire and request a new hose set. They are very helpful.
    thanks.
    Well, you can overfill the brakes (if you fill out the max but the caliper pistons were not fully inserted in while doing so, and you push them in afterwards - for instance when you install fresh pads), but it won't be causing hose to weep.
    It usually goes out at the weakest point - seals.
