Results 1 to 3 of 3
    Hydro disk n00b, cable routing issues
    I was peacing together my Stumpy FSR M5 frame last night, and ran into a bit of a compatibility issue with my Hayes brakes. The way the brake line exits the rear caliper is parallel to the bleeder circuit/nipple, which means it pushes into the Brain. I see some newer and high end calipers are running a banjo bolt on the brake line, and this is what I need.
    Is there a way to retrofit a banjo bolt setup to my 06 Hayes 9's?
    comeon... nobody can help me with this simple question?
    ups and downs
    Hayes has a 30 degree banjo available, see page 4
    http://www.hayesdiscbrake.com/pdf/45...lishForWeb.pdf
