Results 1 to 3 of 3
    Reputation: Murchman's Avatar
    Hydraulic newbie question on adjusting levers
    I have XTR hydraulic brakes on my new enduro and have never had hydraulic brakes before, coming off of Avid mech's. How do you adjust how far the levers come in before the pads engage the disc? I want a stiffer feel to the levers as they are taking more and more pull before the pads engage the disc.
    just along for the ride
    Reputation: Brown_Teeth's Avatar
    If the contact point is not consistant you have to bleed the brake lines, you have some air in the lines that will make it feel spongy or vapor lock the calipers on heavy braking. If the handle is consistant but too close to the bars there is a hex screw on the handle pivot to adjust the reach, well at least there is on the '04 XT's, good luck
    Does the distance between pads and the rotor also change when adjusting the lever?
  1. Question about brake levers
    By Patchito in forum Weight Weenies
    Last Post: 09-03-2004, 12:23 AM
  2. Replies: 3
    Last Post: 07-08-2004, 12:04 PM
  3. Brake levers question
    By bradifus in forum Brake Time
    Last Post: 04-09-2004, 09:35 AM
  4. Newbie lbs question
    By joshua_msu in forum General Discussion
    Last Post: 03-15-2004, 04:49 PM
  5. Replies: 2
    Last Post: 02-23-2004, 06:58 PM
