Hs33 mystery
Hi everyone,
I have a set of these that I got second hand last year. The front brake is perfect but I'm having a weird problem with the rear one. When I use the barrel for the wear adjustment, one pad get closer to the rim while the other doesn't until the other reach it. The weirdest is that its not always the same side. I have bleeded them using the magura bleed kit but its still not working properly. Could that be a bubble in the hose? If so, how can I get rid of it. Any trick for the bleeding? By the way, I took the bike to my lbs and they didn't do better than me. Any help would be greatly appreciated. I'm trying to set a bike to introduce my girlfriend to mountain biking and these brake would do great (if I can get them to work)!
- You may not post replies
- You may not edit your posts
Forum Rules
