    How to tell if V-Brake Pads are just replacable.
    I need new brakes for my bike and Im not sure if I can buy just the pads or if I need the whole thing. I have a raleigh mojave 2.0 with factory brakes.
    EDIT: Also what is the difference between threadless and threaded pads?
    Meh.
    Reputation: XSL_WiLL's Avatar
    You probably need the whole thing - pad with the post.
    Cartridge style brake pads usually have an aluminum backing. The pad material is held in by a small clip.
    Threadless pads are typically for cantilever brakes and the like.
    Go to your LBS. They can help you figure out exactly what you need.
    OK. I think I have to get threaded because I use Linear Pull brakes.
    nnn
    nnn is offline
    Reputation: nnn's Avatar
    Feb 2005
    Some V-brakes also use so-called peg mount pads (my old STX-RCs for example) so check out what you have, it's one of 3 things:
    *cartrodge pads with replaceable pads bit and solid holder
    *Normal threaded pads
    *Peg-mount pads with no threads
    "Life begins at 140" Richard Burns
    http://www.nikolay-k.com
