    Mar 2005
    How to shorten Juicy Ultimate hoses?
    I don't have these brakes, but am wondering how you shorten the lines. do they come with the hardware needed to do so (like Formula)?
    Hack Racer
    Reputation: Cheers!'s Avatar
    Yes, they come with the extra compression olive. You need a short razor blade or a sharp cable cutter to get a clean cut.
    http://www.youtube.com/user/SRAMtech
    It is the same for Juicy 7 as Juicy Ultimates
    <object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/xUumuMIo6Ok&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/xUumuMIo6Ok&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
    BOSS TYCOON
    go to a shop with a HYDRAULIC HOSE CUTTER!
    LDH
    LDH is offline
    Reputation: LDH's Avatar
    razorblade is fine and if you angle the lever right you won't even have to bleed them.
