    Dr. Pepper drinker
    Reputation: catch22's Avatar
    New question here. How much more work installing 160mm vs 185mm Avid mech?
    I'm considering getting the 185mm front and 160mm rear on my 01 Fuel 90 but not sure if I really need it. I'm guessing the 185 would offer some extra (but maybe not necessary) stopping power but I don't know if it's worth the extra $$ and trouble to get the 185 plus adapters. For those who have have tried the 160s and 185s, how much more does the larger rotor complicate the installation? If it matters, I weigh 180 and ride mostly aggressive xc, fork is the stock Manitou SX-R. Thanks!
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by catch22
    Almost ZERO. Just install the post mount adaptor and bolt on as usual. If you ride long, fast downhills the 185 is worth getting. I use the 185s on both ends on one bike and 185/160 on the other and weigh ~170 lbs.
    mtbtires.com
    On MTBR hiatus :(
    Yeah, what Shiggster says, and it's not just stopping power, it's heat shedding ability of the larger rotor that makes it a winner for extended downhill runs.
    The installation should be the same for either. Just a little fyi I installed a 6 inch on my xc bike and was extremly unsatisfied with the power. Sold it and went up to the 8 inch and was overwelmed with power. I have heard that with the larger rotor the brakes get a little grabbier but with my Avid Speed Dial lever I seem to be able to adjust it out perfectly for my liking.btw 225 lbs and ride agg. XC and urban. JJ
  1. Will Avid Mech work with Coda 4 bolt rotors?
    By Edderd in forum Brake Time
    Last Post: 06-06-2004, 02:44 AM
  2. Help with Avid Mech 185mm setup with Fox Vanilla
    By BlackOut in forum Brake Time
    Last Post: 04-09-2004, 02:22 PM
  3. Avid Mech 185mm Disk, too much power...
    By rpanning in forum Brake Time
    Last Post: 04-03-2004, 08:54 PM
  4. Best deal on Avid Mech 185mm fronts?
    By condoor in forum Where are the Best Deals?
    Last Post: 03-31-2004, 05:33 PM
  5. Disciples of Dirt-Oregon trail work
    By General Coonskins in forum Trail Building and Advocacy
    Last Post: 03-23-2004, 09:43 AM
