Results 1 to 2 of 2
    Dec 2004
    How to mount disc brakes?....
    Well, not quite that simple......
    I replaced my fork recently with a Marzocchi Z150 FR which is a QR 20 through-axle. I also replaced the 160mm rotors for my Shimano XT (4-piston model) brakes with 203mm rotors. Now I need some Shimano adapters to use these 203mm rotors.
    Universalcycles.com has the Shimano rear adapter I need, but not the front. It seems that, according to them, the Shimano adapter needed for the front is different than than that for the back. This I did not expect. They don't seem to have have the one I need for the front (i.e. 51 IS mount mount to 51 IS caliper).
    Can anyone direct me to some place that has the two adapters (Shimano brand preferably) that I need? Any help would be much appreciated!
    Reputation: shiggy's Avatar
    Dec 1998
    Front and rear spacing is different and 20 mm through axle spacing is different than QR. You need to look for a 203mm rotor 51mm to 51mm 20mm through axle adaptor.
    Fun, huh?
    mtbtires.com
  1. What are the BEST brakes on EARTH?!
    By norwoosg in forum Brake Time
    Last Post: 02-24-2005, 10:38 PM
  2. Disc...or V's...
    By BThor in forum Singlespeed
    Last Post: 01-20-2005, 04:47 PM
  3. Need advice on using disc brakes
    By moose in forum Brake Time
    Last Post: 04-05-2004, 11:18 AM
  4. Ahoy! V-brake holdouts!
    By Padre in forum Singlespeed
    Last Post: 03-23-2004, 10:06 AM
  5. regular brakes and disc brakes
    By joshua_msu in forum Brake Time
    Last Post: 03-05-2004, 09:07 PM
