    squirrellyrabbit
    Reputation: squirrellyrabbit's Avatar
    New question here. How to install Razor Rock lever-blades on Hayes levers?
    I found a pair of Razor Rock stiffy lever blades to use with my Hayes disc brakes but I can't find any instructions on the Hayes site for how to remove the existing blades from the brake lever. Does anyone have expewrience with this? Any help you could give is greatly appreciated.
    Reputation: 006_007's Avatar
    Quote Originally Posted by squirrellyrabbit
    On the hayes website there is an entire maintenance manual that includes exploded diagrams.
    http://www.hayesdiscbrake.com/pdf/45...lishForWeb.pdf
    TJ
    If your Hayes brakes have the pressed in pin it is best to press them out with this tool http://www.balleracing.com/BR-150_1.htm or find a shop that has one. Don't hammer the pin out like the Hayes manual says, it could damage your master cylinder housing and crack the plastic bushings. If you have the older 98/99/DH model there is a C-clip you remove. The newer 2003-2004 Hayes Mag brakes use a T-bolt that uses two allen wrenches to install.
    Erik,
    Balle Racing
    www.balleracing.com
    squirrellyrabbit
    Thanks for your replies. I saw the exploded diagram on the Hayes site but I was at a loss about what tool to use to get the pin out. These are probably 2000 or 01 brakes, so I guess I will go on a quest for this tool at the LBS. Wish me luck...
  1. Replacement levers for Hayes discs?
    By Gear Grinder! in forum Brake Time
    Last Post: 06-13-2004, 12:16 PM
  2. Hayes lever getto-mod
    By zedro in forum Downhill - Freeride
    Last Post: 04-13-2004, 02:49 PM
  3. Hayes lever set screw backs out, help?
    By ibmkidIII in forum Brake Time
    Last Post: 03-30-2004, 09:33 AM
  4. Replies: 5
    Last Post: 02-24-2004, 04:44 PM
  5. Tech question re: Hayes brake levers.
    By Finch Platte in forum General Discussion
    Last Post: 02-03-2004, 09:27 PM
