Results 1 to 6 of 6
    How to get 8" rotor for 6" system
    what all would i have to do to get the 8" rotor on the hfx hayes 6" system?
    Reputation: E-man's Avatar
    Quote Originally Posted by IrightI
    You'll need to buy the 8" rotors and the correct adapters to space your caliper farther out.
    Oakley - High Definition Optics
    would the extra braking power be worth the trouble..will i notice the difference?
    You will notice a big change in power switching to 8" rotors. Question is if you need the extra power or not depending on where and what you ride and if it's worth the price. Hayes 8" rotors are around $50/each and adapters around $15/each New.. Note that some bikes can't run the 8" rotor in the rear because it doesn't clear the chainstay.
    Quote Originally Posted by donyel
    that was my next question...will i be able to fit a 8" rotor on a liquid 10?
    The only way to be sure, if you haven't seen another liquid10 with 8"ers is to take it to a good local shop, undo the old rotor and bolt on the shops spare 8" (unbolt the rear adapter/calibper combo so it's not in the way when reinstalling the wheel), then just tighten the wheel into the dropouts and you'll know right away if it works or not. It's normal to only have 3-5 mm's clearance.
  1. What lighting system are you using?
    By Trevor! in forum Endurance XC Racing
    Last Post: 06-18-2004, 11:48 AM
  2. WTF?! Bogus reviews on MTBR
    By weather in forum General Discussion
    Last Post: 03-02-2004, 05:27 PM
  3. New inexpensive light system
    By tl1 in forum General Discussion
    Last Post: 02-20-2004, 06:53 PM
  4. Nicest light cable system?
    By Hardtailforever in forum Weight Weenies
    Last Post: 02-20-2004, 07:29 AM
  5. Good lightweight cable system? (X-post from weight weanies)
    By Hardtailforever in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-18-2004, 10:50 PM
