Results 1 to 8 of 8
    Dec 2010
    How do I undo a undo badly bedded rotors?
    I know better but... I went for a quick lunch ride without bedding in a new pair of rotors. Now both front and back have variable braking. I tried to clean them with isopropl alcohol but it didn't help. Is there any way to unbed the rotors and start over? Is there any chance it will even out?
    B A N N E D
    Brake power is generated by the friction material on the pads embedding into the surface of the rotor, re-bonding to the friction material still on the pads and then breaking apart or shearing. In order for this bonding/shearing to occur, the friction material must first be displaced onto the surface of the rotor. This typically happens during the first 10 – 50 stops of a brake system and is referred to as “burnishing” the rotor and pads. When a rotor is cleaned, it will need to be re-burnished again to re-deposit the friction material onto the surface.
    Dec 2010
    Thanks for the quick response! Good ino. What's the best way to clean the pad material off the rotor? I heard alcohol but that didn't work.
    B A N N E D
    Give the pads and rotors a light sanding with some fine grit sandpaper, clean them with alcohol and then re-burnish them.
    Reputation: mitzikatzi's Avatar
    Or Steel wool and isopropl alcohol
    Duct tape iz like teh Force. It has a Lite side and a Dark side and it holdz the Universe together.
    007 is offline
    b a n n e d
    Reputation: 007's Avatar
    Jun 2005
    Why the heck do you need to clean them?? Unless you are changing to a new pad or new rotor, just keep riding them. They'll bed in properly on their own just fine. The fact that braking is variable (i assume you mean between F and R) just suggests that one set is further along in the bedding process than the other.
    nvphatty
    Guest
    Quote Originally Posted by mitzikatzi View Post
    yes exactly a much better method.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by mrmrm View Post
    Remove the rotor. Lay on a flat surface on a clean cloth. Use 800 grit emery paper and LOTS of water.
    mtbtires.com
  1. Brakes glazing badly
    By Andrew Nance in forum Brake Time
    Last Post: 06-18-2013, 11:41 AM
  2. Replies: 4
    Last Post: 05-29-2013, 05:35 AM
  3. Badly sprained MCL and possible torn ACL.
    By mtbikernc69 in forum Rider Down, injuries and recovery
    Last Post: 03-10-2012, 10:37 AM
  4. A9C CYA Creaking Badly
    By PTB66 in forum Niner Bikes
    Last Post: 02-29-2012, 06:29 PM
  5. I want a mach 4 so badly!
    By timms in forum Pivot Cycles
    Last Post: 02-02-2012, 11:12 PM
