Results 1 to 2 of 2
    Aug 2013
    How do I Loosen M395 shimano hydraulic brakes.
    Brake pads are applying pressure (enough to provide resistance not a full stop) when brake handles aren't depressed, (bike is new). I'm guessing there is an adjustment screw to lessen pressure. Is there something I'm overlooking? (discs are not warped)
    > /dev/null 2&>1
    Reputation: Procter's Avatar
    Feb 2012
    Re: How do I Loosen M395 shimano hydraulic brakes.
    There's a ton of threads on this, search for 'dragging' in this forum.
    Could be centering issue, in which case you can try recentering and/or using various means to nudge while tightening down the bolts.
    You can also push back the pistons with a tire lever or box end wrench.
  1. Shimano M446 hydraulic brakes lost their mojo
    By dbfutrell in forum Brake Time
    Last Post: 04-04-2015, 06:00 AM
  2. Replies: 11
    Last Post: 03-25-2014, 01:16 AM
  3. Replies: 1
    Last Post: 08-26-2013, 07:43 PM
  4. Shimano BR-M446 Hydraulic Disc brakes question.
    By colehasarsx in forum Brake Time
    Last Post: 04-06-2013, 07:42 PM
  5. Shimano XT hydraulic brakes
    By BORDERCOLLIE in forum Commuting
    Last Post: 09-30-2011, 08:18 AM
