Results 1 to 9 of 9
    Jan 2013
    how do i keep a mechanical disc brake housing in the hydraulic brake holders?
    i have a full suspension frame with the the mounts on the frame for hydraulic disc brake set up but i have mechanical disc brakes so my cable housing has a smaller circumference. I tried using electrical tape but that ended up sliding off when i went down some stairs. What can i do to make it fit without it popping out when i go down bumps?
    Quiet Professional
    Reputation: chef7734's Avatar
    Is there a hole for zipties?
    Re: how do i keep a mechanical disc brake housing in the hydraulic brake holders?
    I thought I read here that some people were using the smaller derailleur cables(supposed to help stopping power as well)
    Sent from my DROID RAZR using Tapatalk 2
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by Enduro14 View Post
    My brake cable housing is the same diameter as hydro brake lines. Some housing guides require an insert to work.
    mtbtires.com
    Jan 2013
    there are no zip tie tie downs but i could just zip tie it down to the frame if i had too.
    Aug 2005
    Usually brake cable housing is larger than derailluer cable housing.. At least with jagwire it is. You're are probably using derailluer housing for your brakes. Get different housing and it should work fine
    If you are using 4mm SIS shift housing....you are putting yourself in a very dangerous situation. It cannot withstand the compressive forces delivered by the brake lever and will explode as some point, causing catastrophic brake failure. Regular brake housing and hydraulic housing are the same size (5mm).
    Looking for/WTB : Grove Innovations Assault Fork, Grove Innovation Hammerhead Stem or Hothead Bar Stem
    You likely need a few of these split housing/hose guides. Undoubtedly, a local shop will have them, as the alternative is buying an entire bottle of them.
    May 2005
    When I worked at a shop, I would hand out cable ends and ferrules for free all the time. I hope most shops still do. Apat is right double check and ensure you are using brake cables and brake housing.
    Shifter cables and housing are not as strong as brake cables.
  1. Replies: 9
    Last Post: 07-03-2014, 12:48 PM
  2. lightest mechanical disc brake calipers?
    By FishMan473 in forum Weight Weenies
    Last Post: 07-02-2014, 08:02 PM
  3. Replies: 24
    Last Post: 10-05-2012, 11:09 PM
  4. Mechanical Disc Brake Options
    By stunzeed in forum Brake Time
    Last Post: 06-25-2011, 08:33 AM
  5. Shimano 475 mechanical disc brake pads
    By GOONRock in forum Brake Time
    Last Post: 01-29-2011, 01:17 AM
