    Reputation: laotsu42's Avatar
    how do i get my brake pad back in ???
    i recently injured my back and had to take a week off my bike had to leave it at the store i work at for a couple of days . when i go and get it today i took the wheel off to get it in the car and i guess the pads slipped out and wont go back ...
    this is my first set of disk brakes so i am unclear as to what exactly holds the pads in ...
    how do i get them back in to place
    brakes are avid mechs ...
    thanks ...
    ______
    "thirty spokes converge upon a wheel but it is the hole in the center that enables it to be used"
    Riding free's the mind
    push them back in
    Avid mech pads are easy to remove and put back in. Just make sure the spring clip in sandwiched between both pads, then squeeze them together and should click in. Make sure the pad adjustment knobs are all the way out, then each pad should come out with a tug to get past the clip. Put them back in together.
    Question to a custom frame builder..."So what makes your bikes climb better?"....his answer, "Uh, your legs?"
    -> SickLines.com <-
    Reputation: mtb_biker's Avatar
    Quote Originally Posted by laotsu42
    thanks ...
    i've found its easier to take out both pads, place them in the clip, then reinsert the entire thing at once. You will see how the clip clips in when you remove the other brake pad. Just slip in the entire thing and apply a little pressure and it should pop right in
    sweet ...
    thanks guys ...worked ...and i've been scared to touch them all this time ...i feel silly now ...
    ______
  1. Replies: 13
    Last Post: 01-30-2010, 11:53 PM
  2. blast from the past, cut/paste from archived MTB DOC posts
    By ashwinearl in forum XC Racing and Training
    Last Post: 02-09-2005, 09:47 AM
  3. Big big big brake problem....
    By AdamOn6thStreet in forum Brake Time
    Last Post: 10-15-2004, 01:33 PM
  4. Which brake lever for which brake...?
    By mahgnillig in forum Brake Time
    Last Post: 10-06-2004, 02:18 PM
  5. Avid brake pad replacement alternatives?
    By jdcamb in forum Brake Time
    Last Post: 07-03-2004, 10:39 AM
