    how do i fix this ?
    head of the screw broke when tried to unscrew to shorten the hose, how can i unscrew it ? do i have to buy new lever, or maybe the lever body alone ?
    Reputation: toad's Avatar
    Here's what ya do . . .
    First, go to your local hardware store. There are tools for removing stripped bolts (don't remember the name) that look like drill bits with a threaded cone on the end. They are reverse threaded, and come in a set with different sizes. Buy a set of them (10 bucks?, don't worry you'll use 'em again). Cut the hose flush with the lever body. Find the size that partially screws in, fit a wrench on the end and turn. It should back out with no problem. Then all ya need is a new fitting. -t
    thanks you for your input, i will try it, but i came with an idea, mayby i can rip the cable from the lever and collapse the screw's thread inside so i can pull it out, but i try your method first if i'll find these tools you have described, it seems much more safe
    also works to use a dremel and grind a slit into it then unscrew it but make sure you don't drill into any of the lever
  1. 1/8" spoke thread showing - bad?
    By old_dude in forum Wheels and Tires
    Last Post: 05-30-2005, 02:46 PM
  2. RX100 & General Titus Questions
    By MTBDad in forum Titus
    Last Post: 09-09-2004, 12:52 PM
  3. How much would you pay for a New Demo 9 Frame
    By Chowdah in forum Downhill - Freeride
    Last Post: 02-27-2004, 08:23 PM
  4. a little bit of a fix
    By dompedro3 in forum Singlespeed
    Last Post: 02-25-2004, 12:44 PM
  5. Wow!
    By ernesto_from_Wisconsin in forum Singlespeed
    Last Post: 02-21-2004, 10:44 AM
