Results 1 to 10 of 10
    CT3
    CT3 is offline
    Hoodwink
    Reputation: CT3's Avatar
    May 2010
    how to completely flush the fluid out of brakes.
    i think i bled my brakes with fluid that may have been contaminated with water. how do i flush out all the old fluid. on my avid brakes
    options:
    bleed them by pushing alot of the fluid during the line bleed phase?
    suck out all the fluid dry?
    Quote Originally Posted by CT3 View Post
    ...bleed them by pushing alot of the fluid during the line bleed phase...
    ^^^ This would be my choice.
    Reputation: zenkem's Avatar
    Quote Originally Posted by gmcttr View Post
    +2, Can you see the water separate from the oil or is the fluid milky??? Regardless, I'd keep flushing the system with new fluid...
    007 is offline
    b a n n e d
    Reputation: 007's Avatar
    Jun 2005
    I just did this on my Hopes (unintentionally) . . . I was watching TV as I bled the system and realized that I sent about 3 oz. of brake fluid through. You can tell because the fluid coming from the bleed port was nice and clean.
    Reputation: Shalom's Avatar
    Nov 2008
    Just flush the system with excess fluid.
    CT3
    CT3 is offline
    Hoodwink
    May 2010
    Got it thanks for the info
    I drained my system, unscrewed the hose from the lever and blew it out with a compressor. Not really necessary, but I had just opened a new bottle of fluid and didnt want it mixed with old water logged fluid.
    Pushing fluid thru the system is acceptable but thats a bleed, not a flush
    CT3
    CT3 is offline
    Hoodwink
    May 2010
    Quote Originally Posted by bing! View Post
    thats what im thinking, wouldnt that leave some residual fluid behind?
    is it bad to dry out the system? cant imagine it would but always worth checking
    Bleed = removing unwanted air
    Flush = removing unwanted fluid
    Oct 2011
    I just did a flush/bleed after installing some new Clark sintered brake pads on my Avid Juicy 3's. The play is fine, but their is a delay between when I squeeze and when the brake engages. Additionally they don't seem to be fully engaging when I squeeze: the wheel will still turn even while I'm gripping with full force (it will fully lock after a second or two of gripping, but it's way too long of a delay)
    The brakes seem to be centered well, so I'm left wondering if I screwed up:
    1) the instal of the new pads
    2) Flush/bleed
    3) all of the above
    Any advice would be greatly appreciated. I use the bike for daily city riding and don't feel too safe with the couple second delay between my squeezing the brakes and the time to final stop.
  1. How much fluid is in my brakes?
    By biker99 in forum Brake Time
    Last Post: 08-26-2010, 05:36 AM
  2. fluid for Hope brakes
    By kray in forum Brake Time
    Last Post: 04-18-2009, 08:47 PM
  3. Hope brakes, what fluid?
    By robbbby in forum Brake Time
    Last Post: 01-25-2009, 03:43 PM
  4. Dot fluid - Hope brakes
    By saga in forum Brake Time
    Last Post: 11-28-2008, 08:47 PM
  5. DOT Fluid in Saint brakes
    By jasevr4 in forum Brake Time
    Last Post: 11-08-2007, 07:20 AM
