Results 1 to 7 of 7
    Reputation: ImWithBusey's Avatar
    how to center rotor on disc breaks
    My breaks were once perfectly aligned, but I don't know what happend.. doesnt matter.. now my rotor rubs againts the break pad and I can't seem to center it. Suggestions? tips? trick?
    Bodhisattva
    Reputation: The Squeaky Wheel's Avatar
    What brakes?
    Did you check the FAQ above?
    yes
    yes, and it never really helped me in centering the rotor.
    "El Whatever"
    Reputation: Warp's Avatar
    Again What kind of brakes. Brand, model, type. All of them have different ways to get fixed. Surely you just took the wheel off and put it back on.
    For Avid Mechanicals, just move the red knobs on each side on the caliper.
    For other brakes you need to tell what kind of brake is it.
    Check my Site
    Hayes HFX-9, hydraulic disc
    A few things or a combination of all of them can lead to some rotor rub (assuming the pistons aren't pushed out too far to begin with). Make sure your wheel is straight in the dropouts. Find somewhere where you can see the rotor/pad interface while the wheel is spinnning. If rotor is mostly centered between the pads but has a spot where it bends to hit the pad, then pull out the adjustable wrench and true the rotor. If the caliper is off center and constanctly dragging on one side of the rotor, then unscrew the caliper and do some fine tune positioning until it's perfectly centered.
    mtbr remember
    Reputation: BikeSATORI's Avatar
    Try the card trick to center the caliper.
    Schralp it Heavy.
  1. XT disc v. Hope XC v. King
    By Earthpig in forum Wheels and Tires
    Last Post: 07-13-2004, 11:38 PM
  2. paging all 04 xtr disc users..................
    By marco in forum Weight Weenies
    Last Post: 05-24-2004, 02:12 PM
  3. Ahoy! V-brake holdouts!
    By Padre in forum Singlespeed
    Last Post: 03-23-2004, 10:06 AM
  4. Question about rear disc wheel strength
    By islander in forum Wheels and Tires
    Last Post: 03-16-2004, 02:17 PM
  5. Tune Disc Hubs & Formula Disc Brakes??
    By Wirth in forum Weight Weenies
    Last Post: 03-05-2004, 05:20 PM
