    Toilet Assasin
    New question here. Hope V2 alignment of pads on disk surface
    Hey all,
    just noticed that after a short bed in ride on my new V2's that the pads seem to be tracking approx 1mm under the outer edge of the disk surface.
    Is this normal? The caplipers are flush with the adapters and are perfectly aligned but seem to be sat low looking at the wear line on the disk.
    I realise this is a better situation that running high as otherwise the pads will be wearing wrong and creating a ridge in the top of the pad.
    Can anyone shed some light on whether this is normal or not???
    Thanks in advance. Pics attached to illustrate...
    not as visible as the front disk..
    Pivoteer
    Reputation: tiSS'er's Avatar
    I believe that to be normal. That is how mine look.
    Employed by Pivot Cycles - www.pivotcycles.com
    ultra member
    Reputation: briantortilla's Avatar
    That is also how my x2's look and it is not a problem. If you are really bothered by it you can put some shims underneath the caliper to move it up.
    Somersaults... that's how I roll.
    Reputation: zahgurim's Avatar
    Aug 2005
    Mine were like that, too. I just put a small washer between the adaptor and caliper to get the pads almost flush with the edge of the rotor.
