Results 1 to 3 of 3
    Just A Mountain Biker.
    Reputation: blaklabl's Avatar
    Mar 2011
    Hope Tech EVO X2 - Ok with Avid Clean Sweep rotors & adaptors?
    I have never had a problem using avid rotors and adaptors with Shimano, Magura, etc on my bikes - about to pull the trigger on some Hopes and while I will eventually get the correct rotors and stuff, just wanted to make sure I can roll with what I have for the time being if needed.
    MTBR: Your dad's online mountain bike forum.
    Mar 2011
    OOPS, sorry I just saw the sticky - feel free to delete this post.
    Yes, for the rotors. I don't know about the adaptors. The Evo X2 pad is very close, if not the same, to the height of the BB7 pad. The BB7 pad is much wider. I ran the Cleansweep X on my BB7 and it worked great, but the braking surface is designed for a smaller pad. Your Evo X2's pads will run into the spider of the Cleansweep X rotor. Make sure your new rotors have a larger braking track. You can get by with these rotors if they are not heavily grooved.
