Results 1 to 5 of 5
    Old Bald Dude
    Reputation: CruzinJapan's Avatar
    Hope SS Hoses Installed . . . WOW!
    Here are a couple of pics of the Hope SS hoses installed on my SantaCruz Superlight.
    I wrenched it myself. Not too bad of a job. My only recommendations would be don't get in a hurry, measure many times, cut once. Start with the rear so if you mess up the hose or something you can shorten it for the front.
    I cut the hose with a pair of Shimano cable cutters. I've heard a dremel with a cutting wheel works good too, but I was too lazy to get mine out of the shed.
    Enjoy,
    Chris
    Ted
    Ted is offline
    Ted in real life
    Reputation: Ted's Avatar
    Do you like them? Any noticable difference?
    Old Bald Dude
    Well, our local trails are snowed under, so
    Quote Originally Posted by Ted
    initial parking lot indications are all I can give. So far, things are looking favorable. The hoses don't have any flex that I have noticed so far. Once I can get on a trail, I'll post a better response.
    Chris
    will those hoses fit your existing hyd saddles?
    I just wondered.
    Bob
    Old Bald Dude
    hyd saddles?
    Quote Originally Posted by bobde
    I just wondered.
    Bob
    If you are refering to the hose guides that are used to keep the hose running along the top tube, yes. The outer diameter of the hose is the same as the original equipment black plastic hoses.
    The connectors at the end of the hoses are noticably smaller than the original connectors. This give the hose/brake a much cleaner look.
  1. New Hope SS Lines/Hoses
    By thebronze in forum Brake Time
    Last Post: 02-03-2005, 08:12 PM
  2. Emerging SS Perspective
    By waltaz in forum Arizona
    Last Post: 01-15-2005, 07:40 AM
  3. Singlespeed: More or less efficient?
    By grumpstumper in forum General Discussion
    Last Post: 01-13-2005, 01:01 PM
  4. ss fun at the tourne
    By mergs in forum New York - New Jersey
    Last Post: 11-29-2004, 09:58 PM
  5. to SS or not? that is the question
    By Nimai in forum Singlespeed
    Last Post: 04-28-2004, 11:46 AM
