Results 1 to 1 of 1
    Sep 2012
    Hope & Saints (M810)
    Finally got all the parts for my brake upgrade together and installed it last night. Got my Saint M810 set and Hope tech floating rotors (203f/183r) Ran into a small hiccup that required additional work:
    The rivets on the Hope rotors were contacting the Saint calipers at one of the mount points.
    The clearance was so tight that it was impossible to move the caliper around to get the optimum positioning for pad clearance, so I had to grind off a little of the caliper on the inside surface to clear the rivets.
    Total amount ground off was a little under 1mm, and everything works nicely now.
    Looking closely at the 203mm Hope rotor I think it's a litte out of round......gotta look for my runout indicator gauge....
    Just a heads up for you guys if you're planning this combo.
    -S
