    Reputation: natoz's Avatar
    Oct 2010
    Hope Pro3 SP AM4 - Which Disc to replace?
    Hi all,
    Got a really noob question, need some help.
    I bought a set of Hope Hoops Pro3 DT Swiss few years back. http://http://www.chainreactioncycle...l/rp-prod80556
    Today, i notice the rotor is bent, and i require a replacement. been doing some digging on CRC and Hopes website, but i cant be sure which rotor need to purchase to fit this hub (Pro 3 SP AM4). http://www.hopetech.com/webtop/modul...ntExploded.pdf
    Can an expert kindly point me to the correct rotor i should buy? I am really confused...
    Many thanks!
    Quote Originally Posted by natoz View Post
    Hi all,
    I bought a set of Hope Hoops Pro3 DT Swiss few years back. Fix LINK
    Many thanks!
    Fix Link, Brakes and/or Hub..??
    Oct 2010
    http://www.chainreactioncycles.com/au/en/hope-hoops-pro3-dt-swiss-front-wheel/rp-prod
    B A N N E D
    Hope makes 4 bolt rotors for their own 4 bolt hubs, for Rohloff 4 bolt hubs, for Formula 4 bolt hubs and Coda 4 bolt hubs.
    http://www.hopetech.com/page.aspx?itemID=SPG314
    Looks like you'd need:
    HBSP195:183:4H
    MV2 DISC - 183MM 4 BOLT - HOPE
    HBSP195:203:4H
    MV2 DISC - 203MM 4 BOLT - HOPE
    HBSP208:160:4H
    MM 2/4 SAW DISC-160MM 4 BOLT HOPE
    HBSP208:180:4H
    MM 2/4 SAW DISC-180MM 4 BOLT HOPE
    HBSP208:183:4H
    MM 2/4 SAW DISC-183MM 4 BOLT HOPE
    HBSP208:185:4H
    MM 2/4 SAW DISC-185MM 4 BOLT HOPE
    HBSP208:200:4H
    MM 2/4 SAW DISC-200MM 4 BOLT HOPE
    HBSP208:203:4H
    MM 2/4 SAW DISC-203MM 4 BOLT HOPE
    HBSP208:205:4H
    MM 2/4 SAW DISC-205MM 4 BOLT HOPE
    Get a LBS to order one or maybe try one of these shops:
    http://www.southside-mountainbiking....-4-bolt-rotors
    http://www.wowbikeparts.de/hope/hope...scheibe-4-hope
  1. Old Hope Rear Hub: Replace Freehub Body or Buy a New Hub
    By abikerider in forum Tandem Mountain Bikes
    Last Post: 05-28-2013, 10:15 AM
  2. XTR brakeset to replace Hope tech M4
    By justbuster69 in forum Brake Time
    Last Post: 05-24-2012, 05:23 PM
  3. Replies: 0
    Last Post: 05-22-2011, 08:22 AM
  4. Hope Hoops Pro3 SP-XC or Mavic Crosstrail UST
    By mrm1 in forum Wheels and Tires
    Last Post: 04-30-2011, 06:49 AM
  5. help locating Hope Disc Mono 6 Saw Disc
    By SHIVER ME TIMBERS in forum Downhill - Freeride
    Last Post: 04-20-2011, 11:58 PM
