Results 1 to 5 of 5
    WOY
    WOY is offline
    Hope MONO MINI V2
    Hi!
    I am wondering if anyone would know of a place where I can pickup a set of Hope MONO mini Version 2 which were produced between 2007 / 08.
    Better still if someone has a set for sell!
    Prefer them over the current set.
    Thanks,
    Wayne
    There is no such thing as a "Mono Mini V2"
    There is:
    -Mono Mini for the years you specified, which is the silver caliper
    -There is a V2, which is something completely different.
    The reason I state this is because there are right now a lot of people not getting this, and doing such things as deciding "between a V2 and an X2 (the replacement for the Mono Mini).
    The picture below will display a side by side of the 06 Mono Mini against an 07 V2 when someone in 07 mentioned that the Mini is a V2:
    And the pad difference:
    Quote Originally Posted by Jerk_Chicken
    There is:
    Is that an avid adaptor,if so what size and brand rotoe are you running...
    Correct. I actually bought the brake from this site, lightly used. Avid adaptor, I run a 203 vented rotor in the front.
    Tulsa
    Reputation: rojogonzo's Avatar
    I have an older version(?) than that with a smooth cover that says hope on it and a 3 on the leg, does it use the same pad as your 2007/08? Sorry to hijack i'm trying to get a set fixed up for my Black Buck build. I need a longer rear hose and new pads.
    tia
