Results 1 to 5 of 5
    Programmer
    Nov 2006
    Hope Mono Mini retaining pin stuck
    Just like the title says... the retaining pin is definitely not sliding out, with any ease anyway. I've put some serious "pull" on it too, nothing. Any suggestions? Should I try and hammer it out?
    Reputation: Kiwiplague's Avatar
    Quote Originally Posted by work-ed View Post
    Only if you want to buy a new caliper!
    Personally I'd try a small amount of WD40 on the thread of the pin, let it soak for a couple of minutes and try again. Any excess force is not going to be overly good I would think on the pin.
    Rippin da fAt
    Here is a link to an exploded view. There is an o ring as well as a pin to deal with. It shows no threads to deal with. Light lube and pin punch should do to push it out.
    http://www.hopetech.com/webtop/modul...erexploded.PDF
    Programmer
    Nov 2006
    Got it!
    In case someone else stumbles to this thread. I basically just pushed on the pin from the opposite side and while doing so, used a small flat head screwdriver and pried the pin loose eventually popping the o-ring out. Hope replacement pads include a new retaining pin, so I wasn't worried about damaging the old one. Thanks for the replies.
    Rippin da fAt
    Glad to hear you gotter done!!!
  1. Replies: 5
    Last Post: 03-30-2006, 12:27 AM
  2. Hope Mini Upgrades/Changes (Not Mini Mono)
    By myitch in forum Brake Time
    Last Post: 08-26-2005, 12:55 AM
  3. Replies: 7
    Last Post: 04-23-2005, 11:54 PM
  4. Can anyone help me find Goodridge for Hope MM's? Or Hope Mono Mini Rear 140's?
    By Nicholas Broskovich in forum General Discussion
    Last Post: 06-23-2004, 04:46 PM
  5. My new HOPE MINI MONO (or MONO MINI ?)
    By pintense in forum Intense
    Last Post: 03-09-2004, 04:48 PM
