Results 1 to 2 of 2
    Hope Mini question
    I was abel to get a used Hope Mini disc brake. I have a few questions:
    1. What does the number 5 on the caliper signifies? Is it related to rotor size?
    2. I tried to see if the opening between pads can accomodate my Avid Juicy 7 (160 mm) rotor but it seems that the rotor is thicker so it won't fit. Is there a thinner rotor that I need to get? I thought the rotor thickness is standard.
    3. Can someone post a picture of the caliper with the pads installed (view from the pad opening)? I just want to see how the end of the pads align to the caliper body.
    Thanks a lot for the help.
    May 2005
