Results 1 to 36 of 36
    ...idios...
    Reputation: SteveUK's Avatar
    Idea! Hope Mini Disc Brake Overhaul
    This is a guide for a complete overhaul of a Hope Mini disc brake. Included in the guide are directions for removing and replacing the seals in both the caliper and the lever, ‘refreshing’ brake pads and bleeding the system. The instructions for bleeding the Mini (and M4) are copied directly from Hope’s manual, though my own notes are added in italics. Manuals and schematic diagrams for all Hope products can be downloaded from www.hopetech.com.
    Through experience I’ve found that reusing rubber seals can sometimes be problematic, so, to be on the safe side, it’s worth having a set of new seals ready. Seal kits are available from suppliers of Hope brakes. This guide assumes that you will be using a full new seal kit.
    Hydraulic fluid is an irritant. Always wear safety glass when working with hydraulic fluid. If you do get any in your eyes, rinse immediately with water and seek medical advice.
    Hydraulic fluid will damage or remove paint. Isopropyl Alcohol is excellent for wiping away hydraulic fluid. I usually use clean tissues to wipe up spills then go over it again with a tissue and a few drops of alcohol.
    I’ll start with the seal change. Although it’s not 100% necessary, at least for the lever, it’ll make your job much easier if you disconnect the lever and caliper from the brake hose. I drained the system when I did this procedure, but you should be able to retain the fluid from the hose if you wish. First of all, remove the wheel and brake pads. If you have a work stand; no problem, otherwise you’ll need to ‘jack the bike up. As you can see in the pictures, I just rest the chain stays on a small toolbox. The pads can be removed by unscrewing the pad retaining bolt that runs through the caliper. This may have a metal ‘R’ clip on the other end; just slide it off. Slide the pads and spring out of the caliper and put them somewhere where they won’t get contaminated.
    It's worth having a small container handy to drop all the components into as you remove them. I usually drip a little alcohol onto each part as I remove it with a view to cleaning/drying thoroughly before refitting.
    These are the torque settings that Hope advises for the Mini caliper;
    Hose Connector 8Nm
    M6 Bolts 8Nm
    M5 Bolts 4Nm
    To drain the system, first attach a length of pipe to the caliper bleed nipple (2). I send mine into a hole pierced in the top of a jam jar, but you can just drop the end into a pot/jar. At the lever, remove the top-cap and diaphragm from the reservoir (3/4).
    Using an 8mm spanner, loosen the bleed nipple a half turn (5) and allow the fluid to drain before removing the pipe.
    Place a cloth/tissue to catch any spills and use an 8mm spanner/socket to remove the hose bolt assembly (6). Holding on to the hose to remove any tension will make it easier to remove this bolt, and also reduces the likelihood of damaging the threads. Wrap the hose end in tissue and tie it up. It is not necessary to remove the connector unless you're shortening/replacing the brake hose. I've only done it here for the purposes of illustration. Picture (9) shows the assembly; two copper washers, hose connector and bolt and the brass olive. Leave the bleed nipple in place as you'll need it for getting the pistons out. Remove the caliper from the frame, making sure you collect any washers/shims that are used for centring the caliper/rotor. Make a note of how many/which came from which bolt.
    Remove the two bolts (5mm allen) that hold the caliper halves together (10). It is possible that these bolts will be very tight, so you may need to hold the caliper with a cloth, or even bolt it back onto the frame to allow you the necessary leverage.
    Split the caliper into its two halves (11) and remove the small rubber 'o' ring from its recess. NB. All the other seals in the Mini caliper are Hope only. The small 'o' ring, however, can be found in the plumbing section in most large hardware stores.
    To remove the pistons from the caliper I use an old bleed nipple, a length of 5mm pipe and my tyre pump (12). A track pump works best for this. The pipe makes the job a little easier and also stops the pump from being contaminated with DOT fluid, as it will cause the rubber to perish. Note the plumber's PTFE tape on the nipple.
    Screw the bleed nipple into the caliper half, attach the pipe/pump and back the nipple off a half turn. Place a cloth over the piston (important!!) and your thumb over the fluid hole (where the 'o' ring was) and compress the pump. You may have to pump it a few times, but the piston should eventually pop (literally!) out of the caliper body. The cloth should catch the piston and any fluid that is ejected from the caliper. Transfer the pipe assembly to the other caliper half and repeat the process.
    You'll now have two halves and two pistons (make a note of which piston came out of which half). Depending on how long the brake has been in use the pistons may have a rim of dirt (13). This should only be removed with a cloth/tissue. Resist the urge to use glass-paper as the piston is a precisely machined component. Use alcohol if the dirt is particularly stubborn.
    The rubber seals in the caliper (14) can be carefully removed with a small point or jewellers screwdriver (15). Do take care not to scratch the caliper surface/piston bore.
    (16/17) Clean both halves of the caliper down using alcohol and prepare the new seals. Dip your finger or a cotton bud into some DOT fluid and run it around the recess' for the seals. Also apply a thin layer onto the whole of each seal. Carefully push the each of the seals into their recess', making sure they are properly seated. Apply a thin layer of DOT to each piston and push it slowly into its piston bore (18). Rub a thin layer of DOT to the 'o' ring and its recess' and drop it in. Note that one half of the caliper has a deeper recess for the 'o' ring.
    Thouroughly clean the facing surfaces of each caliper with acohol (19), ensuring there is absolutely no dirt or grit which may prevent the two halves mating up cleanly.
    Push both pistons fully into the bores and bolt the two halves back together. Don't screw one bolt in then switch to the other; thread one in a little and then do the same with the other so that compression is similar on each. When the caliper halves are fully torqued together the pistons will need to be pushed fully into their bores in preparation for bleeding the brake. I use a block of pine wood that I filed to the correct thickness (20). The distance between the two halves of the Mini caliper is 11.5mm.
    The Mini/Mono/M4 Lever
    Most of the fluid will have drained away long ago, but it's worth stuffing a little tissue into the lever reservoir. Use a 10mm spanner to loosen the hose bolt (21) then remove the two bar clamp bolts from the lever. When the lever is free from the handlebar, unscrew it all the way from hose (24). Wrap a lttle tissue around the joint to catch the dribbles (22). Note the copper washer (23).
    Use an 8mm spanner/socket and a 3mm allen key to remove the lever pivot bolt/nut (25), and a 2mm allen to remove the lever piston pin (26). NB Turn CLOCKWISE to remove the pin from the brass barrel (27).
    The piston seal is held in place with a retaining clip. This can be carefully prised out with a small jewellers screwdriver (28) or use the circlip pliers.
    The piston assembly is sprung, and held in place with a brass washer and a circlip (29). You will need a set of circlip pliers to remove/replace this circlip (30).
    With the circlip removed the pin and washer can be pulled out (31)(remember it's under a small spring load).
    Use a soft/round tipped tool to poke the piston assembly through and out of the lever body. Do not use a screwdriver. A 3mm ball-end allen key is ideal (32)
    Picture (33) shows the full lever assembly. Take note when you remove the piston which way the two piston seals sit. I they are fitted the wrong way around they will not function.
    Clean all parts with alcohol. Prior to refitting the piston, pour a little DOT fluid into the piston barrel and run a thin layer around both piston seals. Insert the piston/spring into the barrel and carefully push it all the way in (34).
    Insert the piston pin and brass washer. Whilst compressing the piston, use the circlip pliers to refit the circlip over the brass washer (35). This is a bit fiddly, and may take a few attampts to get it all straight, so take your time.
    The piston seal and clip can now be replaced and the lever refitted.
    Refitting the lever to the hose is the opposite of removal. Remember to fit the copper washer.
    Once the hose is reconnected and tightened up, the lever can be refitted to the handlebars.
    You're now ready to refill the system with DOT fluid…
    Bleeding the Mini and M4 disc brake
    Wear safety glasses
    1. Remove the wheel and brake pads to prevent contamination
    2. Push the caliper pistons back into their bores and insert a spacer between the pistons to prevent them coming out during the bleed operation. (spacer is 11.5mm, pic.20)
    3. If necessary reposition the brake lever so that the lever and master cylinder is horizontal to the ground.
    4. Remove the master cylinder cap using a 2mm allen key (2.5mm on the newer, flat-top bolts). Then remove the rubber diaphragm.
    5. Place the closed end of an 8mm spanner over the bleed nipple on the brake caliper. Fit a length of clear plastic hose (approximately 30cm) onto the bleed nipple and place the free end into an empty container. The hose should be a snug fit and not fall off, the free end does not need to be submerged under brake fluid.
    6. Fill the master cylinder reservoir with brake fluid.
    7. Open the bleed nipple a turn. Slowly pull the brake lever to the handle bars and hold. Close the bleed nipple. Release the lever. Caution, squeezing the lever too fast will cause brake fluid to squirt out of the master cylinder.
    8. Repeat step 8 until no air is seen coming out of the bleed nipple. You will need to keep filling the reservoir during this operation. Caution, if bleeding a rear brake be careful not to spill brake fluid onto the front caliper and disc.
    9. Ensure the pistons are fully retracted in the caliper, the pistons may require manually pressing back.
    10. Place a rag around the master cylinder to catch any spillage and fill the master cylinder to just below the top surface (36).
    11. Place the diaphragm into the master cylinder and allow the fluid to overflow (37). Close the bleed nipple and remove the bleed hose. Caution, do not over tighten the bleed nipple. Wipe away any spilt fluid from the caliper and lever.
    12. Fit the master cylinder cap and gently tighten with a 2mm allen key (2.5mm on the newer, flat-top bolts). Caution, do not over tighten cap as you are only sealing the rubber diaphragm (38) (At this point you may want to refresh your pads. Trace a figure 8 on a piece of 100ish sandpaper until the pad surface is evenly cleaned/deglazed (39)
    13. Replace the pads (40) and insert the wheel. Pull the lever several times to allow the pads to reset themselves to the disc.
    14. Check the brake for correct function and that there are no system leaks.
    Here's what Hope have to say about bedding your pads in;
    " To achieve the maximum braking effort the new brake pads need bedding in. Bed in the
    pads by riding a short distance with the brake applied, it also helps to pour clean water over the
    caliper and pads whilst bedding in. This procedure will achieve good braking performance but will reach its full potential after a few rides."
    Head outside with a bottle or pint glass of fresh, clean tap water. Get up a head of steam and brake hard. Pour water liberally over the caliper. Pedal off again, this time with the brake applied lightly. As you pedal you're going to feel the pads bedding in to the rotor. Keep going, pulling the brake gradually harder as you have to pedal harder. Do this for 20-30m and then pour water of the caliper again. Repeat a mix of hard stops, water; brake/pedal, water until your brakes are hpow you like them. I can get two Hope Minis bedded in in under 10mins using this method. They'll improve further after a little trail time, but at least you'll have decent braking to begin with.
    Rotor can be 'roughed up' in a similar way, though you should use a less abrasive paper, something like P320. Work across the rotor's braking surface, not around it, and make sure you clean it with alcohol when you're done.
    Peace,
    Steve
    Diogenes
    Reputation: pablo_b's Avatar
    Great stuff, Steve... very detailed and very complete. Well done.
    Is there any way you can add links to bigger versions of the pictures? I've overhauled the master cylinder/lever on the Mini levers, and I know that the details of doing that are not shown very clearly on the smaller photos you've included. A bigger set of photos for those small parts in the lever assembly would really help for the person who is new to the procedure.
    Thanks for this great resource!
    ...idios...
    Hey pablo_b,
    OK, I've redone the images for the lever overhaul. Three per line now, rather than five and the lever assembly has its own line! If anyone requires larger pictures for this or any of my other guides, just mail or PM me and I can mail a folder of full size (30cm) images which you can view on your desktop.
    Thanks for the heads-up, pablo_b,
    Peace,
    Steve
    Diogenes
    Brilliant,
    I really appreciate your efforts on your bike maintenance series.
    MTB Monkey
    Reputation: Jefe74's Avatar
    Mar 2006
    I just rebuilt my old 2001 Hope Enduros (old Pro levers, 4 pot 2 pc calipers) and was really impressed with the Hope rebuilt kit. It was reasonably priced and included everything to completely refresh the brakes: new square seals, internal O rings, master piston, springs, circlips, diaphrams, etc. About the only wearable item not included was the delrin washers at the lever pivot, oh, and pads.
    However, Hope had to get fancy and use little lighting bolt shapes as the cut outs in the rotors. I found several cracks from the tip of the bolts to the outside edge of the front rotor. It did last 5 years, and had worn down in thickness so should have been replaced anyway. No surprise that the new rotor has just simple round holes.
    But overall, major props to Hope for continuing to support their old designs. These things should last forever with periodic rebuilds. The design, machining, and materials of the levers and calipers is still state of the art and justifies keeping them around.
    Also, DOT brake fluid is pretty nasty, particularly 5.1. Get some nitrile gloves from the auto parts store, as I think brake fluid can eat through latex.
    - Jeff
    Reputation: misctwo's Avatar
    killer writeup....can you do formula brakes? K24's?
    Triathlete/MTB Poser
    Reputation: tri-dog's Avatar
    Mar 2006
    Very nice write-up! A couple questions:
    I have a set of Minis and the rear is pumping up under heavy braking (when it gets good and hot). I already did a complete fluid change so no water in the fluid, and I did ensure the pistons were completely compressed before capping the master cylinder so it isn't over-full. I assume there is a problem w/ the expansion of the fluid that the lever should accomodate, any suggestions?
    Second, how much heavier are these than the new mono-minis? Worth paying to upgrade or just try to fix mine (front works fine)? Hate to replace if there's no real gain.
    ...idios...
    What exactly do you mean by pumping up? Are the pistons sitting too far out when the system is hot?
    Mar 2006
    Quote Originally Posted by SteveUK
    Correct, the lever travel reduces and the brake begins to drag.
    ...idios...
    My suggestion would have been that there's too much fluid in the system, which you say you've covered. Out of interest, how high did you fill the res. before putting the diaphragm in? Was it a new diaphragm? If not, did you clean and dry it before refitting? (please don't take offence, but..) The diaphragm is the right way up?
    What size rotor is the rear? Is it possible that you're asking too much from your brakes? Do you 'hang-on' or are you economical with your braking?
    Pardon me if I'm going through things you've already checked/disregarded, this kind of thing is way easier when the bike is in front of me...
    Mar 2006
    All fair questions!
    It's been some time since I tried to use them (pulled them off and went rim brake for Leadville 100 as they we causing too much hassle too close to the race) so I'd have to open it up to verify fluid height and orientation of the diaphragm (I had it open a few times, I'm pretty sure it's correct). It was not a new diaphragm though, what is recommended for cleaning? IPA? (Isopropyl Alcohol, no India Pale Ale...) How close to the top of the resevoir is proper fill height? These are all things I can check pretty easily.
    I beleive they are the 165mm, but I don't have them in front of me right now unfortunately. I don't think I'm trying to overuse the brakes, worst case is just controlling speed on fireroad descents and even then I try to just pump, but it becomes an issue pretty quickly even just pumping the brakes. I'm pretty much a wuss, so it's not like I'm doing any DH/FR stuff w/ them. =)
    For some reason it's hard to find retailers in the US selling the master cylinder rebuild kit, which is where I was about to go until I found this thread.
    ...idios...
    Yep, alcohol for cleaning, then dry off completely so it's as close to a new diaphragm as possible. For filling (picture 36), I fill so that the top of the fluid's concave is a half-mil from the top of the reservoir. There should be a tiny bit of fluid over-flow when the diaphragm is put in place.
    If the problem isn't stemming from a fluid issue, there's a possibility that the piston seals are involved. The pistons are 'controlled' by the seals (they pull the pistons back after the fluid has pushed them out), so if they have started to harden, perish or are just worn-out, then they'll not be doing their job very well. As you say you're not really over-working them this could be worth checking (take the wheel out, put a piece of folded card between the pads and depress the lever once or twice; do the pistons return fully to their 'rested' state?)
    As far as seal kits go, you could try Chain Reaction Cycles in the UK, they post to the US and you'll be able to knock the tax off the screen price. It might be worth sending them an email and seeing what it'd all cost.
    Mar 2006
    Great, thanks for the advice! I'll check the master cylinder stuff and clean up and reinstall the diaphragm. The pistons seem to work smooth and return nicely, if I can't see anything else I'll probably get the seal kit and master cyl rebuild kit and see what happens. Still cheaper than replacing the brake.
    ...idios...
    Let us know how it turns out, it's always good to have definitive solutions to problems like this.
    Peace,
    Steve
    Diogenes
    Mar 2006
    Will-do! Thanks again!
    Mar 2006
    As promised,
    Figured I'd post the promised updated. I verified the MC diaphragm was in correctly, and that the piston was full seated during the bleed, still was having trouble. Ultimately I pulled the caliper apart and found contamination inside, looks like there was a small amount of water in the caliper that wasn't coming out as part of the bleed process. Seems better now but the return isn't that smooth, probably just need to replace the seals which I was finally was able to get from www.ride-this.com. Also, it turns out the rear is the 145mm.
    Piston position question
    Are both pistons (Left & Right) supposed to have the same amount exposed? I was able to get a used Mini and it seems that I cannot fit my rotor. I noticed that the left piston is sitting more inward than the right. I guess to simplify my question does both pistons have to be sitting equidistant from the inside of the caliper body? Thank you for the help.
    ...idios...
    Typically, the inner piston will protrude further from the caliper than the outer piston when they are in their 'working' position. Remove the reservoir cap and diaphragm, put a cloth under the lever to catch spills, remove the pads and use a plastic tyre lever to push both piston right back into the caliper. Then start again with the set-up and shimming process. Are you using the wavey Mini rotor?
    Diogenes
    Dear Steve,
    Thank you so much for your efforts! I can see how useful this can be although it might not be of help for me since I have Shimano XT calipers... which brings me to my question:
    Is there such thing as an overhaul kit for Shimano XT calipers? I just purchased a used set of XT hydro brakes from a friend, and the front leaked pretty badly from the caliper itself.
    I have rebuilt automotive calipers in the past, if I knew where to get a Shimano kit I would be happy to rebuild it because that is the only thing I am missing before I can ride my bike again.
    Thank you in advance,
    -Walter
    Rotor being used
    Steve,
    Thanks for the answer on the caliper question. Anyway I tried it using my Avid Juicy 7 rotor and an aftermarket rotor (I think it was Delta or A2Z). Both rotors will not fit on the opening between pads (it wouldn't even go in). Am I using the wrong rotor thickness? I don't know if Hope Mini uses a thinner rotor. Please help. Thanks
    ...idios...
    Walter,
    Give XSL_Will a shout (PM or post in Brake Time). I have zero experience with Shimano brakes and I remember reading one of his posts where he explained which Shimano calipers can be overhauled. I had a quick look on Chain Reaction Cycles and they don't stock any seals or similar service parts for Shimano, so it doesn't look entirely promising. There's almost always a way around any problem, so give Will a shout and see what he says.
    Steve
    ...idios...
    Back to the Mini troubles....
    First up, you really need to be using a 165mm rotor with the (front) No.5 Mini caliper. The wavey Hope design is specifically intended for use with the Mini, although any 165mm rotor with a wide track will do.
    As far as I know, pretty much all rotors are 1.8mm thick. If the pistons are pushed fully into the caliper, although there may be 0.5mm protruding, there should be more than enough room to fit the rotor, bearing in mind that the pistons will come to rest even further out when the pads are set by pulling the lever a few times. Get those pistons pushed back and try your rotor again.
    I was able to push back the pistons. Now both pistons are sitting almost the same in the caliper. But both pistons don't sit not flush enough on the caliper so the rotor still did not fit. What could be the problem here if the pistons do not site flush enough on the caliper. If I force one caliper to site really flush on the caliper the other will come out more. Is there a quick fix for this? Thanks for the help.
    Walter, Give XSL_Will a shout
    Steve, I just did. Thanks for the advice, I'll keep you posted!
    -Walter
    ...idios...
    "What could be the problem here if the pistons do not site flush enough on the caliper. If I force one caliper to site really flush on the caliper the other will come out more. Is there a quick fix for this?"
    Have you removed the reservoir cap and diaphragm (seal) when you're pushing the pistons? The most obvious reason for the pistons not depressing fully into the caliper would be that there is too much fluid in the system (sometimes people over-fill in an attempt ot alter the bite point of the brake). The other reason for them not returning, and in particular if they're too far out to allow a rotor between the pads, is that the base of the piston has protruded beyond the caliper seal. This can require a relatively large amount of force but nothing that you can't get using a plastic lever. Don't be shy with the force you apply to the pistons, there's nothing for you to damage.
    Steve,
    I removed the reservoir cap and some of the oil came out but the pistons are now ok. You are right that there's too much oil on the brake. I even shortened the brake hose without bleeding so it's all good now. Thanks for the help.
    ...idios...
    Sorry to bump this thread, but the edit function has expired on all of my posts here. Anyway, I've added a Mono (one-piece) caliper overhaul to this series, which can be found by following this link.
    Diogenes
    Reputation: xJAHx's Avatar
    Hello, Steve. Thanks for posting this tutorial. I just replaced the master cylinder kit in my 2006 Mono Minis. Without your help, I am certain that it would have been more of a task. This was a 15 minute in and out job!
    JAH
    great titps here. having some trouble getting one piston to retract fully post rebuild (this was the problem that also made me rebuild the brakes) so will try the other tips re: resetting the pistns with the res cap off - this could very well be the issue i think...
    if it is the seal not retracting the piston correctly is there any way to lube the caliper/piston interface??? will this help??? any recommended products??? i see WD40 is specifically NOT recommended here for obvious reasons... what about silicon spray? normal bike lube???
    You'll have to speak up, I'm wearing a towel!!!
    Quote Originally Posted by spirometre
    something I do fairly regularly on my Enduro4s is to remove the pads and carefully pump one piston out at a time (be cautious, as you don't want it coming out). Clean the piston with some tissue and then drop some Dot4 fluid onto the piston where it goes into the caliper. Make sure it goes all around the piston. Push piston back in, then do the rest of the pistons in the caliper. When they're all done, clean off any excess fluid, reinstall pads and you're good to go. Always fixes any uneven piston problem I have (and with 4 per caliper, it's a real problem ).
    I used to use silicon grease, but that just attracted dirt and made the problem worse.
    awesome.
    will try that tonight
    T.W.O.
    Reputation: mimi1885's Avatar
    Thanks Steve, that reminds me it's time for my overhaul.
    Feb 2013
    Right for 2 days now i have try'd to get my mini rear to stop leaking at the caliper, firstly all i was doing was changing the hose, but then thought i'll swop the cliper for a #5 so i can run a bigger disc.When i first connected everything up it was" seemed" fine , bleed it then noticed a little fluid on the top of the caliper , wiped it away thinking nothing off it and went for a spin.came back fluid again on the top.drained it , took apart caliper and fitted new O ring, still it leaked, so went back to the old caliper set up and that started to do the same, so took this one apart fitted new O ring and it still leaks. I at a loose i really dont know what to do with it as i have done this meny times befor and never had a issue, so can anyone help befor i fire the brake as far as i can throw it, the wife falls out with me for swearing in the garden and i kick the dog. as after 2 days trying i've had enougth of hydro brakes and am going Avid BB7's
    Double-check that fluid is actually leaking from the caliper and not from the end of the hose (ie some people forget to install the small copper washers when fitting the hose).
    Then, check your workshop basics: locate all bolts first, before screwing in each bolt a bit at a time. You run the risk of deforming the mating surfaces of the caliper halves if you drive in the bolts super tight one after the other without locating them first.
    Also, you should lubricate the o-rings with DOT fluid before installng them.
    Might pay to check that the hose is screwed into the caliper on the inside and the bleed nipple is on the outside. This fixed the problem described above on my e4s. Does the caliper visibly flex at all when you apply the brake?
    Self Appointed Judge&Jury
    Oct 2000
    Some great info. Steve thank's. I'm bumping this thread so I can find it easier in a couple weeks when I overhaul my Hope Mini's.
