Results 1 to 2 of 2
    Team NFI
    Hope Master Cylinder
    Have a C2 that is still going. Have one minor problem. That being at the lever- the piston is starting to leak a bit. When I look at the schematic I see that the rubber seals can be removed. So in theory I could find replacement seals to do the job. Is this feasible?
    I ask as I recall once seeing a guy fix his leaking seal on another brand with a seal from a Moen faucet washer/seal set.
    Reputation: Shalom's Avatar
    Nov 2008
    Definitely feasible. There are rebuild kits available. If you cannot find the correct one, try emailing Hope. Their CS is brilliant.
  1. Hope Tech Union Jack Master Cylinder lids
    By Timm in forum Brake Time
    Last Post: 07-15-2011, 10:05 AM
  2. Hope Mono M4 master cylinder/caliper compatibility?
    By anotherbrian in forum Brake Time
    Last Post: 07-02-2009, 12:35 AM
  3. Replies: 12
    Last Post: 04-09-2009, 03:05 AM
  4. Replies: 1
    Last Post: 07-26-2008, 08:59 AM
  5. Hope Master Cylinder Damaged?
    By mtnfiend in forum Brake Time
    Last Post: 04-27-2006, 09:38 AM
