Results 1 to 2 of 2
    VP Motivation L&F Society
    Reputation: Fanaticbiking's Avatar
    Hope floating rotors with XTR
    I wanted to (only for a visual affect) use some read Hope floating rotors 160mm's on my XTR (960 series) brakes? The hubs are Kings and I wanted the rotors to match. Will this be a problem? Will it even work?
    "Daaaannnnnnng!'
    - Joseph Dirte'
    If they are post mount calipers then you will have to file a bit of material off the caliper at one end (you will see where, the rivets off the disc will rub)- i've done this with Saints and it works fine. If they are I.S. calipers then they should work straight off, without modding.
    You can't make a racehorse out of a donkey, but you can make a fast donkey.
