Results 1 to 7 of 7
    Hope Floating Rotor Straightening
    What is the best way to straighten out a floating rotor? I put my new one on today and it is not straight.
    ride hard take risks
    Reputation: dogonfr's Avatar
    Jan 2005
    Take it back where you purchased it, should be covered under warranty.
    Formotion Products
    http://www.formot
    ...idios...
    Reputation: SteveUK's Avatar
    Straighten out the same as any rotor, by carefully bending with an adjustable wrench. The obvious difference with the two-piece rotor is that it's only the steel rotor you're trying to adjust - not the aluminium carrier - so the twisting/bending action you make with the wrench is much smaller. I tend to find the two-piece rotors easier to true.
    Diogenes
    Reputation: mtnbiker1973's Avatar
    Quote Originally Posted by dogonfr
    I've never owned a new set of Hope brakes that have come with a straight rotor.
    Jan 2005
    Quote Originally Posted by mtnbiker1973
    Poor quality??
    Formotion Products
    http://www.formot
    Thanks. That will be a project for this week. One was fine the one I put on the front wasnt.
    Jan 2005
    Quote Originally Posted by mtb_Frk
    If it's new and you attempt to straighten it and it gets worse odds are your warranty will be void, at least throw the responsibility back to where you purchased it let them make the decision.
    Formotion Products
    http://www.formot
