    Hope disc compatability with centre lock adapters?
    When I changed the front disc on my Hope Mono Mini Pro's to 183mm I found that the DT Swiss centre lock to IS adapter would not fit. The opening on the floating rotor was too small. However, they fit fine on the 160mm discs.
    I have since sold those brakes and ordered a set of the new Tech M4's with 183's F&R. Does anyone know if they work find with the DT swiss 6bolt adapters? Do the shimano adapters work better?
    So I will answer my own question... just had delivered my new brakes and yes, the 183mm rotors do not fit my DT Centre lock adapters.
    Can anyone confirm that the shimano adapters will work?
    New question here.
    L1
    I'm running Juicy 7s on DT Swiss hubs with a centre lock adaptor.Work fine for me. Question I have for you is:
    I want to change my front 185mm Avid for a Hope Floating 183mm - red centre looks sweet - d'you know if that 2mm difference makes a difference?
    Anyone?
    Don't know for sure but I doubt it.
