Results 1 to 2 of 2
    hope calipers with avid rotors
    Will Avid rotors work with hope tech v2 calipers? I know they "should" as long as i match the adapter with rotor but im wondering if the pad track width is the same.
    Never trust a fart
    Reputation: frdfandc's Avatar
    They should work with the correct bracket. You might have to use washers to shim up the caliper if it rides low on the rotor brake track.
