Results 1 to 17 of 17
    Hope brakes and 180mm rotor
    I bought two sets of hope brakes.
    1st bike set: M4 Front X2 rear
    2nd bike set: X2 front X2 rear
    On both bikes I would like to run 180mm rotors for the front.
    The adapters I have are the Hope 183mm adapters.
    Is there a way to run 180mm rotor front on both bikes? What kind of adapter would I need since the Hope one is for a 183mm rotor?
    Reputation: Jakerz's Avatar
    Jun 2013
    Would 1.5mm really make a difference? Maybe remove some material from the adapter?
    Jake
    I've read yes 1.5mm makes a difference when the pads start wearing down.
    Never enough time to ride
    Reputation: squish's Avatar
    You will likely end up with a ridge on the top of both pads that will eventually touch and not let the pads close completely on the rotor. If it were me I would get the Hope rotors, mine have been fantastic as have the brakes, I have two bikes one set m4/x2 the other x2/x2 with the same rotors. Or you could get the correct 180mm adapter from another manufacturer, that would be the cheaper route.
    Happy trails...
    Squish
    Get out and ride!
    Jun 2012
    Yeah I just used hope rotors with mine and I think they are 185 not 183 but I could be wrong, been a few months since I did the rebuild.
    Hope does use the 183mm rotor, Avid used to use a 185mm but has since switched to a180mm. Not completely sure why Hope uses the odd ball rotor size.
    Happy trails...
    Squish
    Get out and ride!
    Quote Originally Posted by squish View Post
    Happy trails...
    Squish
    A divided industry that can't agree on a 5mm difference.
    Hope step-up mount 'F' (for a 160mm rear rotor) will enable you to run a front 180.
    007 is offline
    b a n n e d
    Reputation: 007's Avatar
    Jun 2005
    Happy trails...
    Squish
    It's all about proprietary parts.
    OP, get the right adapter or right rotor size. Contrary to what women tell you . . . size does matter.
    Quote Originally Posted by 007 View Post
    Valid point, every ones has to sell more parts. i do like the floating rotors very much though. nCan certainly tell a difference on a longer ride with lots of braking, I find the rotors pinging as they cool down rather fun and fade isn't much of an issue even for a big guy like me.
    Happy trails...
    Squish
    Get out and ride!
    you just need a shimano 180mm adapter or NSB adapter for abit more bling.
    Quote Originally Posted by Broadica View Post
    ...or Hope step-up mount 'F'.
    Quote Originally Posted by MrBadger View Post
    mount F is for IS mount... i assume the fork is quite recent and required POST mount adapter for the front.
    Ah, all becomes clear, thankyou!! I'll get me coat....
    North Shore Billet then, for sure.
    Happy trails...
    Squish
    I've got a barely used set of 160mm Black Floating rotors if you are interested.
    I would mount your 180 on your wheel first and check the pad vs rotor alignment. There are small variances in fork post/tabs. I run two wheel sets with 180 and a third wheel with 183. One fork I have a Hope F post mount adaptor and the other fork I bought a Formula IS 180 adaptor. All fit like a glove. The 183 is run on the bike with the hope adpt and I don't have to adjust anything between switching wheels.
    High Ho Sultan, Lets GO
    I found my Shimano 180mm rotor adapter works well with the hope brakes. Thanks for the suggestions.
  1. BB7 w/180mm Rotor
    By datmony in forum Brake Time
    Last Post: 10-10-2012, 04:09 AM
  2. Replies: 5
    Last Post: 04-19-2012, 08:44 PM
  3. Rear BB7 with 180mm rotor- 2 ?'s
    By bitewerks in forum Brake Time
    Last Post: 12-14-2011, 02:12 PM
  4. Problem: Hope Race X2 with 180mm front rotor?
    By BairdM3 in forum Brake Time
    Last Post: 08-29-2011, 10:48 PM
  5. 180mm rotor question
    By Gilly32 in forum Brake Time
    Last Post: 04-16-2011, 08:19 PM
Members who have read this thread: 4
