Results 1 to 8 of 8
    May 2013
    New question here. Hope Brake Setup
    I know this topic has been hammered out before, but a lot of the riders in those posts are a bit smaller than me. I'm 6' 250 and ride mainly XC and all mountain on a 29er hardtail. I'm looking for a new hydraulic brakes. Currently I'm running Avid BB7s so it's time to switch. I've narrowed it down to Hope brakes. At first I was set on the X2s mainly because of their weight, but after reading the forums I'm concerned these won't be powerful enough for me. I like the idea of running a M4 up front and a X2 in the back but do you think this will be enough for me? Or would I be better off going with the V4?
    I'm just messing with you
    Reputation: wv_bob's Avatar
    I'm pretty happy with my X2s. They'll slow it down to where if I went any slower I'd fall over. I don't ride long downhills though, maybe fade would be a problem there, I really don't know.
    OTOH, there's really no such thing as overkill only overbudget.
    Chasing bears through the woods drunk with a dull hatchet is strongly not advised
    007 is offline
    b a n n e d
    Reputation: 007's Avatar
    Jun 2005
    At 250lbs, I'd definitely put at LEAST an M4 up front. Even better - specifically for AM riding - would be a dual M4 or V4f/M4r setup.
    However, I like to be able to stop on a dime without locking things up and with minimal pressure on the lever. More powerful brakes allow me to do this, and I don't care what they weigh.
    Jan 2011
    205lb rider with Hope M4 front (Sintered Pads)-180mm rotor and X2 rear- 160mm rotor. This set up has worked great riding throughout CO (including BME) and Moab without a major weight penalty.
    Mar 2013
    X2 is not a very strong brake. I found them merely OK for Whistler and North Vancouver XC trails. Nicely made easy to bleed and adjustable but not what I want for where I ride. I weigh a little over 140#.
    May 2013
    Update. I went ahead and got the M4 for the rear. Deciding on weather to put a M4 up front or a V4.
    Also, slightly switching subjects, what do you think about rotor size? I've always had 160s with my BB7s. Will I see a big difference switching to bigger ones?
    007 is offline
    b a n n e d
    Jun 2005
    Quote Originally Posted by lhovden View Post
    I run 183 front and rear. Wouldn't consider anything smaller.
    Jun 2012
    I am 220 I run M4 front and rear 183 MM rotors
  1. Help with Hope brake diagnosis
    By smilinsteve in forum Brake Time
    Last Post: 09-07-2013, 08:46 AM
  2. Hope M4 setup help needed
    By laurenlex in forum Brake Time
    Last Post: 06-19-2013, 09:37 PM
  3. Hope Brake Pad Compatibility ??
    By Enduramil in forum Brake Time
    Last Post: 04-23-2012, 05:22 PM
  4. Replies: 3
    Last Post: 10-10-2011, 05:48 PM
  5. Mavic EX823's on Hope Pro 2's (anyone running this setup)
    By RamRider in forum Downhill - Freeride
    Last Post: 02-25-2011, 06:19 PM
