Results 1 to 11 of 11
    Hope brake locking on
    Its an M4, anybody got an idea why?
    Reputation: 006_007's Avatar
    ummm, squeezing the lever too hard?
    Meh.
    Reputation: XSL_WiLL's Avatar
    System is overfilled?
    its been fine for about 2 years, so I dont think its overfilled.
    ...idios...
    Reputation: SteveUK's Avatar
    Is this any use?
    Diogenes
    wyrd bi ful rd
    Reputation: chinaman's Avatar
    interesting thread that one ... Steve ... cheers ...
    this got me thinking ... not good ...
    what actually keeps the pistons apart after applying the levers ... i notice they go apart even if stationery ... dont tell me it is atmospheric pressure? as after you release your levers ... the pressure within the system will then push the plunger at the lever end back and this effect will pull the pistons slightly apart???
    ...idios...
    The spring in the lever (picture 33 in this thread) pushes the lever piston back to 'neutral', taking the fluid with it (because the system is sealed). That, and the action of the caliper seals basically doing the same thing (returning to neutral) pulls the pistons back into the caliper.
    Diogenes
    wyrd bi ful rd
    Quote Originally Posted by SteveUK
    ... (picture 33 in this thread) ...
    that is contribution to mankind.
    why is mineral oil not recommended for hope set-ups? no reason why oil would damage any seals.
    Meh.
    Quote Originally Posted by chinaman
    Same reason you don't put DOT fluid in Shimano/Magura brakes. Different seals are different types of rubber and different durometers. They are designed to work specifically with their respective fluid type.
    Is this any use?
    Cheers Big ears, Love you like a Brother!!
    All fixed.
    ...idios...
    "Cheers Big ears, Love you like a Brother!!"
    That's the way it goes, Big nose!! Glad you're sorted.
