Results 1 to 7 of 7
    Team NFI
    Hope Brake Compatibility
    Just curious about the newer Hope brake levers. Are they compatibile with the older version systems? Same fittings? When I say older, I mean the silver lever with black body, with the reservoir on top.
    No, they are different and non-compatiable.
    Yes. The black Mini master, the 07-08 silver Mini master, and the new Tech levers are compatible. The Tech is also being used on Moto applications now.
    ...idios...
    Reputation: SteveUK's Avatar
    Any open-system Hope components are interchangeable. There are some subtleties in difference with the fittings, like where early (O2 or C2) brakes used a 6mm hose, but for the most part it's a non-issue. Do you mean that old? Or are you referring to the Mini lever? What exactly are you wanting to do?
    Diogenes
    Team NFI
    I have various Hope bits and pieces lying around. I have an old Hope Mini- the precursor to the Hope Min Mono I believe. It's the one with the silver caliper. And from what I can tell the lever looks the same.
    i do have a set of new Tech Levers. Front Tech V2 with 5mm goodridge hose.
    Rear Hope Mini (not Mono) with 6mm brake hose. Works Fine.
    Team NFI
    Good to know.
    I ask as I got my hands on some Hope brakes through my work. And we where doing clean out when the parts where found in a box. He asked if I wanted them and I said sure. And got the stuff for free. Needs a bit of work and good to go.
    Though one of the caliper will present a bit of a challenge. It's one of the old C2's and is missing a magnet on one of the pistons.
