Results 1 to 3 of 3
    Reputation: MtnMuncher's Avatar
    HFX-9 bleed confusion
    This is my first time working on hydraulic brakes and am in the process of bleeding them. As I am reading through the Hayes instructions, it says:
    8: Close the caliper bleeder.
    9:
    10: Open the caliper bleeder 1/4 turn
    Is this simply done by tightning and loosening the bleed screw? When it is tight it's closed, to open loosen screw 1/4 turn?
    I just answered my own question. I thought the bleed screw was just a port with a hole thru it, not realizing it's sealed off completly when it's tightend.
    One thing that crossed my mind as I was finishing up the bleed was, why dosn't the hydraulic forces push that plastic resevoir plug out of the lever?
    Reputation: Danke's Avatar
    The harder you push on the inside of the seal the tighter it closes. You have to push from the outside to open it.
