Results 1 to 6 of 6
    rebmem rbtm
    Reputation: juancho142's Avatar
    Feb 2010
    HELP: Shimano Mineral Oil to bleed Tektro brakes???
    Hi, I need to bleed my Tektro Draco brakes and ive been searching many LBS but they do not have tektro mineral oil available. Some DO have Shimano Mineral Oil. A guy at a LBS told me i could use Shimano oil w/o problems.
    Is there any issue with this or should i just go with the Shimano oil??
    Just go with it.
    Never trust a fart
    Reputation: frdfandc's Avatar
    I've used the Shimano Mineral oil on Tektro's and vice versa. Currently using Finish Line Mineral Oil for servicing brakes that utilize mineral oil.
    Zero issues.
    rebmem rbtm
    Feb 2010
    Cool guys thanks! So no problems with mixing oil then
    Reputation: Nickbm3's Avatar
    Quote Originally Posted by frdfandc View Post
    Zero issues.
    Im curious about using non-shimano mineral oil too. As posted above, is mixing ok? Or should you drain all shimano oil, and replace with Finish Line oil for example?
    "That's a niiiiiiiice biiike boy! That a Huffy!?"
    Jan 2009
    mix or replace
    Quote Originally Posted by Nickbm3 View Post
    This is the question I have and was searching the forums. I would assume it would be okay but would like to hear from experience whether it caused fading or any lack of performance. Thanks!
  1. Shimano mineral oil and Formula brakes
    By Danish Dynamite in forum Brake Time
    Last Post: 06-17-2008, 11:31 PM
  2. Replies: 12
    Last Post: 06-16-2007, 07:40 AM
  3. Can I use other mineral oil for shimano brakes
    By mirelay in forum Brake Time
    Last Post: 03-20-2007, 02:53 AM
  4. Where To Get Mineral Oil for Shimano Brakes?
    By myitch in forum Brake Time
    Last Post: 08-17-2006, 10:23 AM
  5. mineral oil type for shimano disc brakes?
    By jpusl in forum Brake Time
    Last Post: 12-02-2005, 01:39 PM
Members who have read this thread: 7
