Results 1 to 5 of 5
    Reputation: peletonnissen's Avatar
    HELP need Avid G1 rotors 203mm....
    Help if you can please, I need to source some original Avid Juicy rotors in the 203mm size for a super special project bike of mine. I need these ones in particular as they are the only ones i can modify for this project. If you have any of these in good condition (new if you have them, but good is fine with me) please PM me or post here as i would greatly appreciate it. Here is a pic of what the original looked like. Happy hunting. Also, i will pay for these rotors. Also, there is a few pics of what my modified rotor looks like. I appreciate all the help i can get sourcing these rotors!
    Ibis Cycles
    www.ibiscycles.com
    the giant.
    Reputation: gbosbiker's Avatar
    why did you mod your rotors?
    looks like he cut out the original center so it could be mounted on something that has a larger bolt-spacing. pretty nifty - whatcha workin on?
    Oh noes. I'm going to drink the Kool-Aid.
    much more info on this cross post...
    http://forums.mtbr.com/showthread.ph...24552#poststop
    Ibis Cycles
    www.ibiscycles.com
    the modified rotor fits on a hub with an offset axle (bearings run in the hub flange, not around the axle), and its adapts a 29" wheel to fit on a standard 26" 20mm fork... super-uber top secret kill-all 29er bike...
    Ibis Cycles
    www.ibiscycles.com
