Results 1 to 6 of 6
    Mar 2013
    HELP... magura hydraulic rim brake
    ok, so I'm starting a new project bike a 1998 Cannondale f3000 but the bike doesn't have the brakes so my question is should I thy to get a set of the Magura hydraulic rim brake or should I get a set of Shimano xt rim brakes, I have no experience with the Magura's but it would be cool to have the Magura's but they're also heavier and more expensive than the Shimanos. If you happen to have a set of Maguras that you don't need let me know. btw the brakes don't have to be the same year as the bike
    I wouldn't bother with the Maguras. I love them on my trials bike, because they have absolutely no modulation and go from fully off to fully locked when you so much as touch the lever. That same behavior would really suck for normal riding. Obviously with the right pads and setup for your riding style they can be decent, but unless you really really want Maguras I would stick with regular V-brakes.
    If you do want them, HS33s are usually on Ebay for around $85.
    Mar 2013
    ok, thanks for the input. if i can get the Magura's cheep enough i'll get them but if not i'll just get the Shimano's.
    Reputation: CRchris1996's Avatar
    shimano xt v-brakes has a lot of power pair it with kool stop pads and would be even better
    XTR v-brakes are about the best in terms of stopping power. The pads are mounted on a linkage, so they always move parallel to the rim. None better, though they do take a bit more maintenance to keep functioning smoothly.
    Expensive, but the way to go, in my opinion.
    I like the Magura hydraulic rim brakes, but as norton said, their modulation is kind of crummy. If you can find the older levers for them, you can improve their performance greatly, but they are difficult to find now.
    i totally disagree with the lack of modulation comment regarding maggies. if you've got trials pads and tarred rims then yeah, zero mod but with typical xc rims and red pads you'll have excellent control with the maguras. plus, there is nothing even close to hs33's in regard to ease of maintenance. they take a little longer to set up but then... nothing but a pad change here and there, which seriously takes about 45 seconds.
  1. Replies: 8
    Last Post: 03-08-2013, 11:48 PM
  2. Hydraulic Brake adjustment ?
    By rickcin in forum Brake Time
    Last Post: 08-29-2012, 10:05 PM
  3. Old Magura Julie Hydraulic Drop Bar
    By 88 rex in forum Brake Time
    Last Post: 08-27-2012, 11:06 AM
  4. Hydraulic brake light?
    By henry9419 in forum Lights DIY - Do It Yourself
    Last Post: 04-23-2012, 12:05 AM
  5. Hydraulic brake rub
    By Stumpjumper61 in forum General Discussion
    Last Post: 07-01-2011, 07:32 PM
Hot Deals
Contests
Latest Mountain Bike Articles
