Results 1 to 7 of 7
    Tá mé ar meisce.
    Reputation: BeerCan's Avatar
    Help with locking rear wheel / Hayes HFX-9 XC
    I have an issue with my Hayes HFX-9 XC brakes on the rear of my bike. When I am going downhill I cannot use the rears without locking them up. For obvious reasons I do not want this to happen.
    Is there an adjustment I can make to help this? Different pads? The ones on there now are stock (and fairly new). I will even go as far as replacing the caliper if that is the concensus (no holy wars please). Bottom line is, I am nervous on any bigger downhills because I cannot control my speed correctly. fronts are fine but they are shimano xtr's.
    Thanks for help/opinions.
    To see what is right, and not to do it, is want of courage or of principle. -- Confucius
    Come join me at the Swamp
    Reputation: MikeDee's Avatar
    Basically, there is no adjustment. Try changing the pads and clean the rotor thoroughly with alcohol. I have the same brakes and don't have the problem with them locking up. Are the pads in there correctly?
    Reputation: shiggy's Avatar
    Dec 1998
    Other factors can be tires ( pressure, tread and mounting direction), body position and balance of front and rear brake use.
    mtbtires.com
    Meh.
    Reputation: XSL_WiLL's Avatar
    Shiggy hit it pretty spot on.
    The Hayes HFX-9s are very touchy though, little to no modulation.
    Double-metric mtb man
    Reputation: Psycho Mike's Avatar
    Well, I wouldn't go as far as XSL_Will, though other brakes may be easier. I have had very little problem modulating mine to skate locking up but get maximum braking under a variety of conditions.
    I think Shiggy is right on the money...there are a lot of factors at play and the brakes are just one of them.
    As if four times wasn't enough-> Psycho Mike's 2013 Ride to Conquer Cancer Page
    Moran? Let your opinion be free -> F88me
    Tá mé ar meisce.
    Quote Originally Posted by shiggy
    OK makes sense. Would more pressure in a tire contribute to lockup or less?
    Just for reference on the downhills I am talking about my ass is most definatly over the rear tire. I am using a panaracer fire XC mounted as rear with 38LBS of pressure. I also use very little if any of the front. I am also heavy if that matters (240LBS).
    Thanks for the help guys. Somtimes as a noob you need the experience of others to push you in the right direction. Also to help you know the difference between **** and shinola. This board has been great for that.
    Dec 1998
    Quote Originally Posted by BeerCan
    Could be either. You have to experiment.
    The Fire XC could be too small for your weight. Also if you have it mounted in the "rear" direction it will have less braking traction than if in the "front" direction.
    mtbtires.com
