    pronounced may-duh
    Reputation: Maida7's Avatar
    Apr 2005
    help lever won't bounce back, caliper won't retract, pads rubbing on the rotor.
    I have magura martas. On the front brake, when I pull the lever and let it go it dosen't go back all the way to the open position. Since it dosn't open up the pads don't retract all the way and they constantly rub on the rotor. If my brake toast or can this be fixed.
    Meh.
    Reputation: XSL_WiLL's Avatar
    It may need a fresh bleed. Or it may need the master cylinder rebuilt.
    Mine did the same thing, a bleed fixed it.
    Lead by my Lefty............... right down the trail, no brakes.
    pronounced may-duh
    Apr 2005
    bleed it last night and it's working well again. Thanks for the help
