Results 1 to 2 of 2
    Oct 2007
    Help Elixir On Specialized Epic
    Just upgraded to a set of Avid Elixirs on my 08 Epic. Problem is the rear brake line comes straight out of rear caliper directly in to the Specialized brain. There is no adjustment on the fitting to get it go around around the brain. Is there any place to buy a fitting or banjo bolt with an angle to it to get it over or around the shock brain? I have been looking but have not found anything yet. The way I have it run now I can not get the brake to stop draging because of the pressure on the line pushing out, and it will rub a hole in the line after a while.
    You might be able to get the adjustable banjo from the Elixir CR from Sram or your LBS.
    CAMBr West
    Gives us a couple bucks and we'll give you some trails with sweet jumps and stuff.
