help!!! annoying v-brake adjustment problem
ok so i had the bike shop install new brake pads on my v-brakes. They are cheap brakes, i think they say promax. Anyway, after i get home, on the front brake, after i brake, one of the arms does not fully retract, so that pad drags on the rim. The only way to fix is to manually pull the arm away from the rim with my hands. I do not know much about brake adjustments, but i did look briefly at the park tools repair site,,, and the set screw on the side of the arm is already screwed all the way in.,, Is there another adjustment I can do to get rid of this annoying problem... like maybe does the spring need replaced????? I could take it back to the shop and have them readjust it,,, but was just wondering if this is an easy fix that I could do myself......i hope.
thanks,,
Does the other brake arm have a spring tension screw? If so, loosen it.
But before you do this be sure the wheel is set in the fork dropouts completely.
mtbtires.com
If you tension screw is all the way in, loosen the oposite tension screw.
Thank You, That Worked...
By AdamOn6thStreet in forum Brake Time
Last Post: 10-15-2004, 01:33 PM
By chris corcoran in forum Brake Time
Last Post: 09-13-2004, 02:22 AM
By short shifter in forum General Discussion
Last Post: 06-10-2004, 10:03 PM
By jh_on_the_cape in forum Singlespeed
Last Post: 06-08-2004, 01:24 PM
By nubber in forum Singlespeed
Last Post: 01-25-2004, 08:30 PM
- You may not post replies
- You may not edit your posts
Forum Rules
